Idle or timing problem ,need help???
Old Jul 28, 2005 | 08:57 AM
dohc_si's Avatar
Default Idle or timing problem ,need help???
Hi does anybody know what can be the problem for a 2000 Si,,,i start the car but when i take off it wont let me past over 3.5rpm n if i do ill just die on me...does does anybody know.....thanx
Old Jun 10, 2007 | 03:45 PM
dougshatch's Avatar
Default Re: Idle or timing problem ,need help??? (dohc_si)
I have exactly problem with my EF 91 Hatch i cant go over 3500
Old Jun 10, 2007 | 05:23 PM
RedEj8's Avatar
Do you have any CELs?
Old Jun 10, 2007 | 08:08 PM
dougshatch's Avatar
Default Re: Idle or timing problem ,need help??? (RedEj8)
yeah every time i start it up, I tried get em line up i still got rough idle and still cant go over 3500 rpm
Old Jun 10, 2007 | 08:14 PM
94c1v1cex's Avatar
Default Re: Idle or timing problem ,need help??? (dougshatch)
what cels?
Old Jun 10, 2007 | 08:43 PM
Civette's Avatar
Default Re: Idle or timing problem ,need help??? (94c1v1cex)
car is in safe mode.......pull codes with scanner.....fix problem......
Old Jun 10, 2007 | 08:46 PM
hatchi's Avatar
have you tried using different ecu?? any CEL?
Old Jun 11, 2007 | 06:36 AM
dougshatch's Avatar
Default Re: Idle or timing problem ,need help??? (hatchi)
no its same ECU's i swap a D15 Vtec OBD1 but i swapped the Mainfold from MPFI to DPFI and i runs the harness OBD0 and it idle rough, i never had that problem "TPS FITV IVAC" before in my old motor that blew up I dont have any idea and i dont know where to find the codes lights by the ecus
sick_dc2
Jul 27, 2008 09:58 PM
Lmgrcivic
Apr 11, 2005 11:13 PM
H23AHybridEG
14
Nov 3, 2004 03:38 PM
