2002 EP3-T: what kind of hp numbers possible with 440cc injectors?
Old Jul 28, 2005 | 05:36 AM
djvtoner's Avatar
Default 2002 EP3-T: what kind of hp numbers possible with 440cc injectors?
My car is currently in the shop having my motor rebuilt and i was kind of curious to get an idea of what kind of power i'll be making and/or 1/4mi times.
I have Greddy's turbo kit of the EP3, Arias 9:1:1 comp forged pistons, getting stronger rods, block bored out 20-degrees, RC 440cc injectors, Exedy stage2 clutch, ACT Lightened flywheel, FMIC, and Greddy e-manage (i know i should be going K-pro or neptune but it's not in the cards as of now)
The EP3 makes like 238whp with a stock motor, Greddy turbo kit, greddy FMIC and running greddy's preset boost levels so should i be thinking much higher or around the same?? I'm looking to run 10 psi and the safest tune possible.
Old Jul 28, 2005 | 05:43 AM
B18CXr's Avatar
Default Re: 2002 EP3-T: what kind of hp numbers possible with 440cc injectors? (djvtoner)
At stock fuel pressure the 440's will run out around 10-11 psi
Old Jul 28, 2005 | 05:44 AM
giff74's Avatar
I dont have a guess, but I think it will be way under capacity without better management. I know its easy to say that, $ is king.
djvtoner's Avatar
Default Re: 2002 EP3-T: what kind of hp numbers possible with 440cc injectors? (B18CXr)
ok......then aside from bumping up to 550cc's and a new ECU what do you think could be the best output?
Old Jul 28, 2005 | 10:45 AM
SiR Phil's Avatar
I don't understand why you bothered to build up the A3 motor. With good tuning and 550cc injectors, you can nudge up to the 300whp mark on a stock block... and after that the head supposedly ends up being a major bottleneck.
jestin91
Feb 10, 2013 08:40 AM
B16Civic93
Mar 7, 2005 11:00 AM
Go Fast Civic
Dec 19, 2004 01:52 PM
sohctodohc
Oct 21, 2004 10:55 AM
PJager
Jul 21, 2002 05:25 PM
