need help wiring ob1
Hey, im doing a swap on a 1993 civic CX hatch model, with the jdm d15b vtec, i have a question on how to wire the vtec and o2 sensor to the ecu, i have a d16z6 wiring harness for the motor, i was wondering if anyone knows how to wire it up for vtec and the o2 sensor to the ecu on a CX model, a diagram, step by step chart would be helpful, and i did search for it, but all i could find was minor stuff for other model than a CX. Please i need help!!
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bboy704 »</TD></TR><TR><TD CLASS="quote">^thanks man, but i need it for obd1 for a CX model.</TD></TR></TABLE>The wiring you will need to do is all the same between EG models. The link below is how to add VTEC to the DX, this will work for you..
http://www.hasport.com/Tech/Wring/egdx-vtec.pdf
Enjoy!
Enjoy!
http://www.hondaswap.com/forum....html
try this link...
ps.
if you want to chip your ecu i know someone where you could help you.
try this link...
ps.
chipping is easy and cheap, go to radio shack and buy a small cheap welder, a desoldering pump, a 74HC373 chip, a 28pin socket and a 1K resistor. Solder that **** and enjoy the wonderfull world of tuneability
