JE SRP or Honda CTR Pistons
Old Jul 28, 2005 | 04:30 AM
7rrivera7's Avatar
Default JE SRP or Honda CTR Pistons
I'm currently running the SRP pistons in my B16 which I believe 10.4:1 compression (their off the shelf pistons). I would like to raise compression and was told the CTRs are good for about 11:1 with the B16 head. Can anyone tell me if this is a good upgrade?
Old Jul 28, 2005 | 07:14 AM
B18CR_EJ2's Avatar
Default Re: JE SRP or Honda CTR Pistons (7rrivera7)
yeah it is a good upgrade but you will have to have your cylinders bored to fit those ctr pistons....
Old Jul 28, 2005 | 09:32 AM
7rrivera7's Avatar
Default Re: JE SRP or Honda CTR Pistons (B18CR_EJ2)
Yo9u mean CTR pistons don't come in 81mm?
Old Jul 28, 2005 | 09:34 AM
per4mance's Avatar
you can get standard size cr pistons, run the srp's because they are a forged piston, and they will be good for some nitrous, later.
Old Jul 29, 2005 | 03:11 AM
7rrivera7's Avatar
Default Re: JE SRP or Honda CTR Pistons (per4mance)
Do you think I can run a JR supercharger with this compression?
Old Jul 29, 2005 | 05:58 AM
per4mance's Avatar
i would run a supercharger with as high as 12:1, but i like to push things to the limit to.I think with some injectors a regulator and pump, with hondata or some type of management, you would be fine.Superchargers like compression, so try and keep it around 11:1 to or so, and run the srp's.
Old Jul 29, 2005 | 05:59 AM
per4mance's Avatar
With the compression you have now, you will be fine.
Old Jul 29, 2005 | 08:04 AM
7rrivera7's Avatar
Thanks alot for the help!
Old Jul 29, 2005 | 08:36 AM
cuin9sec
Guest
Posts: n/a
srp forged
Old Aug 1, 2005 | 02:21 AM
7rrivera7's Avatar
Old Aug 1, 2005 | 06:01 AM
non-VTEC's Avatar
i would never switch out forged pistons for stock cast pistons....going from 10.4 to 11:1 is hardly any diffrence......leave them alone!
Gam3_Ov3r
Aug 29, 2007 07:33 AM
team 15
Jun 22, 2007 03:49 AM
MeanD
Feb 10, 2005 08:03 PM
hondacrx90
Jun 21, 2004 06:06 PM
Jmorin
12
May 29, 2004 02:30 PM
