RPM Fluxate Problem
Old Jul 28, 2005 | 03:04 AM
PRoJecTSLeePaLoT's Avatar
Default RPM Fluxate Problem
I tried searching and came up with this thread with the best similar problem to mine: https://honda-tech.com/zerothread?id=1320799
But not exactly the same.
Ok here's the problem. At idle the car is fine. While driving the car is fine usually. In some cases the car bogs (usually at lower rpms between 2-3000 rpms). When I'm at idle and hold on the gas pedal in neutral, the rpm fluxates. For example, if I hold the gas pedal to 3500 rpm. The car will hold it there and then drop to 2000rpm and go back up to 3500rpm and drop and so on. This problem only happens when I'm in neutral and I think this is the cause of the bogging when I drive but it's not a big problem while driving.
What can it be? Someone said it could be my distributor? A while back right when the bogging was really bad I took it to a shop and they told me my timing was off so they adjusted it. A couple weeks later the bogging came back but slowly. Since the timing is all adjusted through the adjusting the distributor do you think this might be the problem? Replacing my distributor? Any advice would help. Thanks in advance.
Old Jul 30, 2005 | 01:28 AM
anyone?
Old Jul 30, 2005 | 07:14 AM
D@nnY's Avatar
Default Re: (PRoJecTSLeePaLoT)
tps or map sensor ..possibly the distributor any codes? any other info?
Old Jul 30, 2005 | 07:14 PM
i can't think of anything else that's out of the ordinary other than the 3 small leaks I have in my exhaust.
Old Jul 31, 2005 | 07:39 AM
D@nnY's Avatar
sounds like tps check the voltage and make sure it changes when you give it gas
KloC 95 EG
Jun 2, 2006 09:24 AM
EVIL_AWD
Apr 13, 2003 12:09 PM
EVIL_AWD
Apr 12, 2003 01:12 PM
BDiddy
Jan 10, 2003 06:50 AM
Boost2NA
Sep 10, 2002 02:33 AM
