bye bye single cam
Old Jul 30, 2005 | 04:53 PM
dirtySOHC's's Avatar
Default bye bye single cam
after two years of boosting the SOHC i finally swapped in something with two cams. In april i started my B20VTEC project and last weekend i finished it up. Many props to the SOHC guys doing it hard but after driving my car i ask myself why i didnt do this sooner.
all OEM
B20B
B16 head
B16 tranny
ssautocrap mani....say what you want....im poor.
t3/t4 .57
P28 crome chipped.....untuned at the moment.
old setup:
new:
the car:
Modified by dirtySOHC's at 6:37 AM 7/31/2005
Old Jul 30, 2005 | 05:03 PM
beepy's Avatar
Default Re: bye bye single cam (dirtySOHC's)
Nice. Did you port out the wastegate hole at all? There is a lot of leftover metal in there that gets in the way, and I think it is the cause of a lot of boost creep issues people have had with the SSAC manifold.
Since the B20 has more exhaust than a B18, I would be extra-careful about the wastegate.
Old Jul 30, 2005 | 05:08 PM
1boostedcivic's Avatar
Default Re: bye bye single cam (beepy)
thats a nice *** car. congrats on that setup how much boost do u plan on running?
Old Jul 30, 2005 | 09:34 PM
Default Re: bye bye single cam (1boostedcivic)
i did notice the wastegate hole and i have to grind it out a little. i've already experienced the creep or spike if you will. with my boost controller turned all the way down i was still able to hit 14psi...only for a split second tho. im running off the wastegate spring now and im getting a good 8psi.
thanks for the props. im planning to run 10-11psi. my next purchase is a wideband which would be sometime after the 15th so until then its no boost.
i love this motor....tq is fun.
Old Jul 30, 2005 | 09:38 PM
couple more pics i found
Old Jul 31, 2005 | 02:36 AM
EnzoSpeed's Avatar
Traitor!
Old Jul 31, 2005 | 06:13 AM
hondaguyef's Avatar
Default Re: bye bye single cam (EnzoSpeed)
OEM goodness . I wondered why I ever wasted my time/money w/ the single slammers also when I switched out. Not bashing the D series Ninjas just my own personal preference is 2 cams and 1.8 liters
Old Jul 31, 2005 | 07:40 AM
cua0's Avatar
rolly: are you running a usdm washer fluid can or did you delete yours?
the new setup looks slick, i want to see what kind of numbers/times you put down with it this year.
what did you do with the Y8? sell the tranny or any of your spare Y8 trannies yet?
Old Jul 31, 2005 | 07:52 AM
cuin9sec
Guest
Posts: n/a
Default Re: (cua0)
carefull with those b20 sleeves man...they cant handle too much power. i wouldnt go over 300-325whp if i were you. good luck!
overall nice setup though...mad props.
Old Jul 31, 2005 | 08:05 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (t67civic)
DOHC F0 Lyfe y0!!!!!!1
Old Jul 31, 2005 | 08:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t67civic &raquo;</TD></TR><TR><TD CLASS="quote">carefull with those b20 sleeves man...they cant handle too much power. i wouldnt go over 300-325whp if i were you. good luck!
overall nice setup though...mad props. </TD></TR></TABLE>
thanks.....i hear you about the sleeves. im a little scared but if it blows then ill just throw a B18B in there.
i know im a traitor but i just had to do something new with my car....it was getting boring.
YiNYaNg
Acura TL, RL & ZDX
16
Aug 9, 2007 10:20 PM
rmathis05
Feb 7, 2007 08:27 AM
actionfigure
33
Oct 5, 2006 10:03 AM
TurboGoKart
Apr 11, 2006 10:51 AM
civicman
Oct 16, 2002 08:30 AM
