Problem installing Tenzo R 17 rims on 2000 Si
Old Jul 28, 2005 | 01:44 AM
FOMULA91's Avatar
Default Problem installing Tenzo R 17 rims on 2000 Si
Hey guys, my friend recently bought some 17-inch Tenzo R and we tried hours to install it, but we never got it installed. The shock is Tein, (adjustable ones) so we raise it and lower it many times but one of the tires is always too low. Is 17-in too big for 2000 Si or do you guys think the shocks and springs are busted? Any idea?
Old Jul 28, 2005 | 01:50 AM
Agent_STFU's Avatar
Banned
Default Re: Problem installing Tenzo R 17 rims on 2000 Si (FOMULA91)
What do you mean, the tires are too low? Put air in them? I'm confused to what you are saying.
The 17"s should fit, just don't lower the car too much, it may rub.
How do you spend hours "attempting" to install wheels?? Wow.
Old Jul 28, 2005 | 02:06 AM
ChewiSi's Avatar
yea, it takes maybe 20 mins. if your by yourself. maybe the car is too low???
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Problem installing Tenzo R 17 rims on 2000 Si (Diseased Dreams)
lol man your icon is sick.
I agree. People have stuffed 19" rims on civics. What is the exact problem here?
Old Jul 28, 2005 | 02:08 AM
Agent_STFU's Avatar
Banned
Default Re: Problem installing Tenzo R 17 rims on 2000 Si (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">lol man your icon is sick.</TD></TR></TABLE>
I know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">I agree. People have stuffed 19" rims on civics. What is the exact problem here?</TD></TR></TABLE>
I'm confused about what the problem is, too. Maybe he is just not raising the car up enough ti fit them, without rubbing.
Wait, maybe the tire size is wrong and its rubbing insanely? I don't know, we need more details.
Old Jul 28, 2005 | 02:21 AM
FOMULA91's Avatar
Ok, when my friend and I tried to adjust the front two tires, it was about one finger gap. That was good. Then the back tires seems too low. When we adjust the back tires, the front becomes too low. we had the same problem over and over.
Old Jul 28, 2005 | 02:22 AM
litterbox's Avatar
I am a (Trial User) Army
Old Jul 28, 2005 | 02:29 AM
FOMULA91's Avatar
Default Re: Problem installing Tenzo R 17 rims on 2000 Si (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
I know.
Old Jul 28, 2005 | 02:36 AM
Agent_STFU's Avatar
Banned
You adjusted the tires? What? You mean you adjusted the height of the coilovers? Keep playing with it, you'll get it eventually.
Now that I think about it, if it took you hours to get this far, you might as well take it to someone who knows a little bit more about this than you do.
Actually, now that I think about it, my grandmother lives in your area.. I'll give her a call, she can probably change a tire for ya.
Old Jul 28, 2005 | 02:45 AM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diseased Dreams &raquo;</TD></TR><TR><TD CLASS="quote"> You mean you adjusted the height of the coilovers? </TD></TR></TABLE>
Tried that up and down.
Old Jul 28, 2005 | 03:01 AM
AutoxEK9's Avatar
When adjusting your coilovers after adjusting one part move the car forward and backward maybe 5-10ft and then jounce the car where you made height adjustments. I.E.(Take your adjustment tool and adjust the driverside rear to the height you want. Move the car forwards and backwards. Then Bounce the Driverside rear and measure.) Do that to the rest of the corners next with the passenger rear, driverside front, and passenger front. Re measure everything after you have made your adjustments. It takes a long time to get ride height correct but relax. Make sure that there is a load on the spring and that it isnt loose from the hat.
Old Jul 28, 2005 | 03:50 AM
b204dr's Avatar
what tires do you have on - sidewall - heights etc- 17's with 60's wont fit lol - need some 45's or 40's no fattys allowed !
Old Jul 28, 2005 | 04:11 AM
drtyhatch's Avatar
sounds like what he is trying to say is, he installed the WHEELS and is now trying to adjust the COILOVERS. It isn't rocket science man, just put the wheels on the car, preset your coilovers before you let the car down and then make adjustments from there.
Old Jul 28, 2005 | 06:39 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, my friend recently bought some 17-inch Tenzo R and we tried hours to install it, but we never got it installed. The shock is Tein, (adjustable ones) so we raise it and lower it many times but one of the tires is always too low. Is 17-in too big for 2000 Si or do you guys think the shocks and springs are busted? Any idea?
17" is not too big and it could be possible that you have blown shocks. To determine that, check for leaks around the shock or pull the shock out and push down on the shaft to see if there is pressure.
Any idea?
Raise the coil over to the highest setting and adjust accordingly.
Old Jul 28, 2005 | 07:52 AM
hoffman4684's Avatar
Somebady doesn't know what he is doing...
Old Jul 28, 2005 | 08:02 AM
sicky's Avatar
grammer nawzi
Default Re: (hoffman4684)
I think reading this thread made me dumber. . . good lord, how is putting on tires hard? I have 17s on my 97 and it took 15 mins for me to do it myself. oH, my head hurts.
Old Jul 28, 2005 | 08:04 AM
FOMULA91's Avatar
Thanks for all the advice. I really appreciate it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoxEK9 &raquo;</TD></TR><TR><TD CLASS="quote">When adjusting your coilovers after adjusting one part move the car forward and backward maybe 5-10ft and then jounce the car where you made height adjustments. I.E.(Take your adjustment tool and adjust the driverside rear to the height you want. Move the car forwards and backwards. Then Bounce the Driverside rear and measure.) Do that to the rest of the corners next with the passenger rear, driverside front, and passenger front. Re measure everything after you have made your adjustments. It takes a long time to get ride height correct but relax. Make sure that there is a load on the spring and that it isnt loose from the hat.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr &raquo;</TD></TR><TR><TD CLASS="quote">what tires do you have on - sidewall - heights etc- 17's with 60's wont fit lol - need some 45's or 40's no fattys allowed ! </TD></TR></TABLE>
I'll check that today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE &raquo;</TD></TR><TR><TD CLASS="quote">Is 17-in too big for 2000 Si or do you guys think the shocks and springs are busted?
Any idea?
Raise the coil over to the highest setting and adjust accordingly.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoffman4684 &raquo;</TD></TR><TR><TD CLASS="quote">Somebady doesn't know what he is doing...</TD></TR></TABLE>
Will it was my first time doing this and I was just a helper.
Old Jul 28, 2005 | 08:31 AM
vtecpoweredsol's Avatar
some1 please tell me... WTF is going on here??? im so confused
Old Jul 28, 2005 | 08:34 AM
EK k kay's Avatar
Default Re: (vtecpoweredsol)
Raise the coilovers all the way up. Install the wheels, lower accordingly.
Old Jul 28, 2005 | 08:46 AM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpoweredsol &raquo;</TD></TR><TR><TD CLASS="quote">some1 please tell me... WTF is going on here??? im so confused</TD></TR></TABLE>
Just having trouble-installing 17 in wheels by adjusting the COILOVERS in the right spot.
Old Jul 28, 2005 | 09:04 AM
rmcdaniels's Avatar
I used to run 17's on my '99. They fit, I just had to use a really low profile tire.
Old Jul 28, 2005 | 09:09 AM
Agent_STFU's Avatar
Banned
Default Re: (rmcdaniels)
You should be running 205/40/17s. Anything bigger, and its going to rub.
Old Jul 30, 2005 | 06:27 AM
Default Re: (Diseased Dreams)
oooo ok i get it. ya my buddy dana had 17s on his 99 si and they rubbed BAD. when he pulled out of his driveway sometimes the tire even hit the fender. it actually started to rust cuz it would get a little bend and chip the paint
Old Jul 30, 2005 | 06:47 AM
Mr. Wonderful's Avatar
Mr. hanes doesnt say anything about adjusting tires
just raise the car all the way up on all four corners then screw around w\ the coilovers that is if the tires aren't too big
Old Jul 30, 2005 | 03:09 PM
scott92hatch's Avatar
set the coils all the way up so then it will fit
Sabres_e
Dec 29, 2009 05:26 PM
EH2_pReStO
May 28, 2004 05:39 PM
starbury
35
Apr 22, 2004 08:18 PM
SilverDc2
Feb 10, 2004 10:29 AM
Boosteddc2gsr
Jun 17, 2003 08:57 PM
