RPM SIGNAL WIRE OR ECU PIN? **SEARCHED**
Old 07-30-2005, 10:09 AM
Pioneer162's Avatar
Default RPM SIGNAL WIRE OR ECU PIN? **SEARCHED**
ok guys, PLEASE don't flame, I have searched the archived content.
I found this thread:
https://honda-tech.com/zerothread?id=798906
and have tried to hook into that wire for my rpm signal on my greddy profec e-01 boost controller. No dice. I don't have a voltmeter accessible, but I'm confident I had a good connection, I've also tried pin A21 on the ecu (obd1) and no dice. I've got all my other guages etc working on the thing (like tps, a/f, vss, etc) via the optional input harness.
Any other ideas?
Old 07-30-2005, 10:58 AM
Relic1's Avatar
A21 isn't the right end of the ignition pulse. it's actually the signal for the ignitor to pulse not the ignitor output signal but it should be really really close.
you want the blue wire from the distributor. If you have the stock engine in there it should be also at the tach wire as posted in the other thread.
If you have a swap go directly to the distributor or behind the cluster. (if your tach works of course)
Old 07-30-2005, 11:24 AM
Pioneer162's Avatar
Default Re: (Relic1)
ok, I'll try the tach wire behind the cluster.
Old 07-30-2005, 01:25 PM
Pioneer162's Avatar
ok, I tried the blue one behind the cluster, and the blue one going directly to the dizzy, still no dice, I think I'm going to need a volt meter, I might have a bad unit. I also double checked my grounds.......everything is working except the e/g rev......wtf
Old 07-30-2005, 01:31 PM
e jay one's Avatar
Default Re: (Pioneer162)
what did you use to splice into the blue wire? its a solid blue one.
Old 07-30-2005, 01:37 PM
Pioneer162's Avatar
I used splice clips, I made sure the splices got through the jackets, I know it's solid blue, I don't think I had the wrong wire......... I need it to work otherwise my rpm offset feature won't work.
Old 07-30-2005, 03:10 PM
Pioneer162's Avatar
solved, I switched the profec controller to 3 cylinders and got a signal? switched it back to 4 and it worked fine....
alex17
11-04-2006 03:46 PM
civiclxb16a
04-30-2005 09:37 PM
Petah
06-01-2004 11:24 AM
AussieK24
05-29-2002 11:59 AM
Ray
06-23-2001 07:21 PM
Quick Reply: RPM SIGNAL WIRE OR ECU PIN? **SEARCHED**
