car shakes at red light
this is not a brake related. i have a 89 dx so my car doesn't have rpm, whenever i'm at a red light my steering wheel shakes very violently. so far i have changed spark plugs and oil change when i bought the car two months ago. any wizards would like to let me know what's wrong?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DieMaster »</TD></TR><TR><TD CLASS="quote">is yours a auto? the idle might be low so the motor is having a hard time keeping it's self going.</TD></TR></TABLE>
its a 5 spd.
its a 5 spd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diseased Dreams »</TD></TR><TR><TD CLASS="quote">low idle. bad motor mounts?</TD></TR></TABLE>
how do you adjust low idle?
This same thing is happening to me when I decelerate. Doesn't matter what gear I'm in, but if I just let my foot off the gas and coast,...the lower the RPM's go, the more it wants to shake. If I down-shift it goes away until the RPM's fall lower in that gear (no lower than 1k RPM...) Think bad motor mounts?
My 89 dx hatch 5 speed same thing. Idle's below 700 and shakes like a bit#@.
Took a look and the front mount rubber is torn. I think the ecu holds the idle steady even if you adjust.
Needs to be About 20% Cooler
unplug the idle ajust motor it has a blk/yel wire and a blu. (on drivers side near cly 1 DPFI) MPFI is on the back pass. side. any way unplughthis and u'llset a code 14 and then adjust idle to 650 base idle. plug it back in and reset computer. idle should now be bout 750. thats normal
Thomas Romspert
16
Jul 22, 2012 09:17 PM
Paprika
May 8, 2007 03:18 PM
