Car shaking when stopped and idling
Hey guys so this is going to sound really odd, when i'm driving the car doesn't shake at all noticably but when I'm stopped at a stop sign or red light it shakes the steering wheel and the dash. Someone said a valve pinging but i'm not sure. I just changed the oil 500 miles ago so i'm not sure what could be causing this. It's kind of freaking me out. Couldn't be the alignment because it only does it when it's stopped.
Re: shaking?
Mounts appear to look fine. it doesn't always do it. I'm not sure where it's idling at because I have to replace the sensors for the speedometer and rpms. I just took them out because they weren't functioning correctly even after being reset. For now my phones my speedometer, did this today.
Re: Car shaking when stopped and idling
By the way I decided to flip the a/c switch in the car (my compressor is out it's shot. putting a new one in) and it stopped for a couple minutes. Not sure if that makes a difference
There's a diagram in the FAQs sticky for adjusting the idle speed. The tach in the cluster is useless for the procedure as it is inaccurate at normal idle speeds. You need to hook up an external tach to do it correctly.
Turning on the A/C raises the idle speed.
Also clean the IACV and replace the PCV valve.
still learning them, haven't owned it that long and bought it off someone else a couple months ago. Modified turbo (kicked on maybe once so far), D15b7 engine with internal modifications it seems and a mini me swap on the head. modified exhaust and fuel system as well.
More of an "oh joy more to fix" if you get what i'm saying. I've been repairing little thing here and there since I got it. I do know quite a bit about the engine so far but little things keep popping up. The car was a sleeper, looked like a normal 92 civic on the outside when I got it. Had no idea what was under the hood until I drove it. Got it cheap though.
