s2000 gauge cluster ques.????
Old Jul 27, 2005 | 07:20 PM
1999CivicSi's Avatar
Default s2000 gauge cluster ques.????
do you think a s2000 gauge cluster would fit in 1999 civic si...if it wont which i dont think it does........does anyone know what type of modification would have to be done if its possible to make it fit?? thanks
Old Jul 27, 2005 | 07:25 PM
DC4_MADMAN's Avatar
Default Re: s2000 gauge cluster ques.???? (1999CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">do you think a s2000 gauge cluster would fit in 1999 civic si...if it wont which i dont think it does........does anyone know what type of modification would have to be done if its possible to make it fit?? thanks</TD></TR></TABLE>
Its more than just a fitment iss with that cluster.
Do a search, there was a good thread a little bit ago on this swap.
Old Jul 27, 2005 | 07:26 PM
xEnderx's Avatar
It can be done, and I am SURE there is a thread about it...matter of fact I know I made one personally a few months ago. Do a search next time.
Old Jul 27, 2005 | 07:57 PM
thanks..keep some info coming
Old Jul 27, 2005 | 08:01 PM
sicky's Avatar
grammer nawzi
Default Re: (1999CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">thanks..keep some info coming</TD></TR></TABLE>
Are you retarded? SEARCH!!!! That's the info, period.
Old Jul 27, 2005 | 08:07 PM
Default Re: (sicky)
theres no need to be an ******* about it, if you dont know dont post..simple..i did look and i couldnt find anything and it would be easier if someone knew the link to the thread or any website that explains it
Old Jul 27, 2005 | 08:12 PM
sicky's Avatar
grammer nawzi
This was hard, read it:
https://honda-tech.com/zerothread?id=1247951
Old Jul 27, 2005 | 08:16 PM
green-'s Avatar
Do you care if your speedometer works or not? The civic VSS puts out a different signal which the s2000 cluster doesn't pick up. I don't want to say that it is impossible to make it work, but you better be pretty damn smart with electronics.
Old Jul 27, 2005 | 08:19 PM
SOHC4life 96's Avatar
Default Re: s2000 gauge cluster ques.???? (green00EX)
It's not only the speedometer, the temp guage nor the gas gauge work.....so basically....you will overheat and run out of gas all the time as well as not know how fast/slow you are going.
Old Jul 27, 2005 | 09:03 PM
thanks for your help..looks like it seems quite impossible..but does anyone know anywhere to get digital gauges or a knock off version of the s2000 gauges that would fit a 99 si
97_dc2
Aug 26, 2014 08:10 AM
CarGuy37
Honda Civic (2006 - 2015)
Jan 21, 2007 01:21 PM
b18c-ivic_gsR
23
Aug 29, 2006 06:01 PM
mugenhatchie
20
Nov 5, 2005 08:56 PM
Type R
Jun 23, 2001 06:40 AM
