engine swap
Old Jul 27, 2005 | 06:49 PM
newera3og's Avatar
Default engine swap
im new to this car thing. but i do know i need a good engine. i have a 1993 civic cx hatch. what would b e a good swap with the least amount of stress. <U></U> PLEASE HELP ME
Old Jul 27, 2005 | 07:08 PM
civicgsr19's Avatar
Default Re: engine swap (newera3og)
The best advice for you is to search, ill be nice, i remember when i was starting out, just read all you can, questions like this here will get you flamed, sad but true.
You have a eg chassis so any B series swap will be relatively easy in comparison to any other chassis.
Old Jul 27, 2005 | 10:04 PM
Spectrum24x's Avatar
Default Re: engine swap (civicgsr19)
Least amount of stress....
B16
strong motor, easy to find, easy swap.
Old Jul 28, 2005 | 01:51 AM
90sedan's Avatar
Search and read up on B series swaps.
A B16 would probably be the best bet.
Old Jul 28, 2005 | 08:11 AM
newera3og's Avatar
what about an h series engine? i was doing research and it said they arent that hard to put in just need some mounts. would that be a good idea?
Old Jul 28, 2005 | 06:38 PM
civicgsr19's Avatar
Alot more work than a B-series, this is NOT a swap for beginners, I recommend doing as much research as possible so you know your getting yourself into before you make up your mind.
Old Jul 30, 2005 | 05:41 PM
newera3og's Avatar
so a b-series is the best bet? b16 or b18?
Old Oct 17, 2005 | 06:04 PM
slixxracing's Avatar
first of all welcome to h-t. and as all the others have said, it's always nice to use the search menu.
on the swap it all depends on what you looking to do and what your goals are.
here's a break down of what each motor roughly costs.
1. H22a prelude jdm/usdm very powerful motor w/ just simple bolt on's (I/H/E, etc..), and ideal for N/A, not too turbo friendly stock. Recommend a rebuild of minor headwork and bottom end work before turboing it. Prices ranges from ~3000-3500 w/ labor @ some local shops.
2. B18c gsr good all around for N/A or turbo. Built pretty sturdy from factory and could handle more abuse you throw at it compared to a h22. (but limit yourself on what you do to it) head's built alot better w/ intake dual valve springs (a must at high rpm) -3000-4000 w/ labor @ some local shops.
3. B16a good mild N/A motor. not as sturdy built as the gsr from factory but w/ minor aftermarket parts it will runs just as good as a gsr swap. afforadable for the price and drives w/ pretty decent power. good beginner swap. ~1000-2500 w/ labor @ most shops.
Hope this helps and gl w/ your search.
Modified by slixxracing at 10:27 PM 10/18/2005
Old Oct 18, 2005 | 11:53 AM
HONDA RR's Avatar
You can either go with a b16 or b18 with a least amount of stress.
Old Oct 18, 2005 | 12:35 PM
Phatch99's Avatar
Default Re: engine swap (slixxracing)
B18c1 gets my vote!
EGToFlyy
Jul 16, 2019 05:40 PM
lj0334
Mar 23, 2017 07:13 AM
binkster
10
Jan 6, 2004 06:16 PM
Thrillhouse
Apr 12, 2002 12:59 PM
TurBoXBirD16
Mar 25, 2002 05:52 AM
