CAR WONT STAY ON PLEASE HELP!!!!
Old Jul 27, 2005 | 06:46 PM
drastikchangez's Avatar
Default CAR WONT STAY ON PLEASE HELP!!!!
the car is a 2000 honda civic ex automatic with 70k miles never had a problem with it until now. there is no modifications at all just a stock car. the car doesnt do it all the time but when it does it idles fine then it drops down to 0 and it turns off. then when i start it it starts right up but once i come to a complete stop it does it again. the check engine light came on and gave me a cylinder misfire code when i reseted the compter it never came back. any ideas would be great thanks.
Old Jul 27, 2005 | 07:09 PM
hondapwr's Avatar
Default Re: CAR WONT STAY ON PLEASE HELP!!!! (drastikchangez)
Could be a problem with the IACV, or Evap solonoid. No trouble codes?
Old Jul 27, 2005 | 07:15 PM
hondapwr's Avatar
Default Re: CAR WONT STAY ON PLEASE HELP!!!! (hondapwr)
Might be a vacuum leak too.. Check your vacuum lines or just start replacing them with nice Akimoto lines.
Old Jul 27, 2005 | 08:28 PM
Andres-eh2's Avatar
Might be signs of a failing alternator.
While the car is idling remove the postive battey terminal, if it shuts off then its the alternator.
Old Jul 27, 2005 | 08:38 PM
CTRwannaB's Avatar
Default Re: (Andres-eh2)
just fixed something like this on a friens car, turns out it was the MAP sensor.
turn on for about a sec then died immediately
changed MAP sensor and worked great
Old Jul 27, 2005 | 10:40 PM
Default Re: (CTRwannaB)
yeah no engine codes whatsoever and usually if i have the ac on or the heater it will stay on but once i turn it off the idle drops and it dies on me.
Old Jul 28, 2005 | 12:03 AM
Default Re: (drastikchangez)
anybody
Old Jul 28, 2005 | 04:51 AM
hondapwr's Avatar
Did you check any of the things we mentioned??
Old Jul 28, 2005 | 01:08 PM
Default Re: (hondapwr)
where is the IACV on this car?
mrbassmx
Honda CR-V & Element
Jan 19, 2017 10:49 PM
jjb193
Aug 25, 2014 09:26 AM
aje151
Feb 6, 2011 07:03 AM
billk2k
Sep 5, 2003 05:17 AM
tmekjian
Jul 28, 2003 04:53 AM
