h22 block notching
Old Feb 19, 2002 | 08:21 AM
WICKED2's Avatar
New User
Default h22 block notching
i'm about to rebuild my engine.....i'm using crower staff on the head
but on the block it would be je piston and stock rod.
my Qs is did any one here notch ther block?
Old Feb 19, 2002 | 04:20 PM
Mikey3000's Avatar
Default Re: h22 block notching (WICKEDII)
why would you need to notch the block? the only reason you need a notched block is for a long *** stroke.
Old Feb 19, 2002 | 08:40 PM
Accord94DX's Avatar
Default Re: h22 block notching (H22Turbo)
what the hell is a notched block?
Old Feb 19, 2002 | 08:47 PM
JG Luder's Avatar
Default Re: h22 block notching (Accord94DX)
If you have H-beam rods then you might have to notch it. I had to on mine. It doesn't take much, and you don't have to be precise. Just make sure you ahve clearance.
Old Feb 20, 2002 | 12:42 PM
Accord94DX's Avatar
I still have no idea...........
Old Feb 20, 2002 | 12:51 PM
JG Luder's Avatar
OK, if what he is asking is what most people are refering to as "notching", then here is the deffinition:
When you have a block, the bottom of the cylinder wall has enough clearance for the stock rods to rotate. If you have an H- beam rod (like I do) then the rod is too fat and it hits the bottom of the cylinder wall on the side. You have to cut out that part of the block to make it fit and able to spin.
Old Feb 20, 2002 | 12:54 PM
Accord94DX's Avatar
Default Re: h22 block notching (JG Luder)
thanks JG
90blackcrx
Oct 2, 2012 06:45 PM
michaelprice83
Feb 1, 2009 07:27 AM
TomTread
Apr 21, 2008 01:35 PM
pbomers
Jun 30, 2002 06:41 AM
LS-G
Jun 8, 2002 04:55 PM
