Tire Wear
Old Jul 27, 2005 | 01:25 PM
97EXB18C's Avatar
Default Tire Wear
Got a problem.......
97 ex coupe
1.5 inch drop all the way around. 15x6 w\205 50s
tire wear on inside rear is really bad and front inside is a little bad
Had an alignment done about 6 months ago by honda, the day after I bought new tires.
Now the same issue....just took a little longer.
my question is.....should an alignment be able to fix this.... ( so I just got a crappy alignment job )
Or do I need a camber kit?
Any help would be greatly appreciated
Old Jul 27, 2005 | 01:50 PM
Crazydave's Avatar
Default Re: Tire Wear (97EXB18C)
sounds like you alignment may not be good,
or you have something wrong
1.5" drop with a stock toe settings should not be eating tires within 6 months
Toe will kill a tire faster than camber
excessive toe + excessive camber = excessive tire wear
Old Jul 27, 2005 | 01:51 PM
IHateJDM's Avatar
did they adjust the toe during said alingment? Camber just changes which part of the tire wears faster, toe changes how quickly the tires wear.
Old Jul 27, 2005 | 03:13 PM
97EXB18C's Avatar
Default Re: Tire Wear (Crazydave)
here are the specs they gave me
before
FL
camber -0.8
Caster 1.1
toe 1.8
FR
camber -1.3
Caster 1.5
toe 8.7
RL
camber -2.5
toe -.8
RR
camber -1.8
toe 3.3
After
FL
camber -0.4
Caster 1.1
toe .8
FR
camber -1.8
Caster 1.6
toe 1
RL
camber -1.9
toe -.8
RR
camber -2.3
toe 1.2
Old Jul 27, 2005 | 05:36 PM
Agent_STFU's Avatar
Banned
Your before toe on one side was 8.7 That'd eat some **** up. Haha, damn.
Old Jul 27, 2005 | 11:50 PM
97EXB18C's Avatar
Default Re: Tire Wear (Diseased Dreams)
ttt
Old Jul 28, 2005 | 05:45 AM
97EXB18C's Avatar
Default Re: Tire Wear (IHateJDM)
help!
Old Jul 28, 2005 | 05:59 AM
AutoXer's Avatar
That toe is still messed up. It may be 'within spec' but it's still pretty bad. It should be 0.
I did my own alignment a few weeks ago, and called 1/8" out good enough because I got tired of messing with it. It ate my tires up, even though it was within spec, set it to 0, and they've been fine since.
Old Jul 28, 2005 | 06:26 AM
Solracer's Avatar
Default Re: Tire Wear (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">That toe is still messed up. It may be 'within spec' but it's still pretty bad. It should be 0.
Hmm I have run with 1/8 toe out up front for years and seen no adverse wear.
As far as the person who start the thread, the 1 inch toe out is a but much, the should get the closer to 0. Camber is still with in spec as most honda's -1.5 is the limit of the spec.
Old Jul 28, 2005 | 06:32 AM
97EXB18C's Avatar
Default Re: Tire Wear (Solracer)
So my question is.....should an alignment shop be able to set the toe at 0? or is an aftermarket product need to set it correctly with my setup?
Old Jul 28, 2005 | 07:11 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97EXB18C &raquo;</TD></TR><TR><TD CLASS="quote">So my question is.....should an alignment shop be able to set the toe at 0?</TD></TR></TABLE>
Yes. If I can do it laying on my back in the driveway using toe plates and a 10' tape for measurement; they should be able to with their computer alignment gizmos.
To set the front toe, the tie rod has a threaded section with a locknut to move the wheel in and out with respect to the vehicles centerline. The rear has a nut with a slotted hole that will allow you to move the trailing arm in or out. These can be set very precisely.
Old Jul 28, 2005 | 07:12 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Solracer &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, I figured it shouldn't be a problem, but I did get wear. Maybe because of my camber? Either way, I just leave it at 0 for the street, then turn the tierod two flats when I get to the track.
Old Jul 28, 2005 | 05:25 PM
97EXB18C's Avatar
any other thoughts anyone??
Old Jul 28, 2005 | 05:48 PM
AutoXer's Avatar
There's nothing really else to be said. Your toe is off. Toe wears tires.
Take it back to the shop and get it re-aligned.
Old Jul 28, 2005 | 09:05 PM
isumase's Avatar
j/w, the numbers you were giving, is that in inches or in degrees because where i work, we use a Hunter laser aligner and its in degrees which gives more room because the one degree will be less than an inch typically.
Coopa B18c5
Jan 18, 2013 07:58 PM
Understeer
Suspension & Brakes
Apr 4, 2006 12:13 PM
samemoore
32
Jan 26, 2006 07:10 PM
xXx Justin xXx
12
Feb 12, 2004 07:51 PM
justininhifi
Jun 27, 2003 10:46 PM
