Rack and Pinion Woes
Hey guys, i just needed to know how much would a brand new rack and pinion would cost for a 1990 dx hatchback, since mines just gave out, and is it hard to install?
just parts just labor or both?
it is a ******* bitch to install i'll asume I've yet to work on a car that it doesn't suck.
When mine goes i'm getting quafies replacement
its not that hard to replace..... if i recall its like 4 bolts, 2 nuts and loosening of a c clamp! a lift will make it a lot easier, however.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper »</TD></TR><TR><TD CLASS="quote">When mine goes i'm getting quafies replacement
Whats the ratio of Quafies replacement?
dont forget the exhaust and shift linkage you need to remove first.
its actually not so bad. there is a trick to it to get the pinion out of the steering column and then out. but youll figure it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmertime »</TD></TR><TR><TD CLASS="quote">Whats the ratio of Quafies replacement? </TD></TR></TABLE>
I think its 2.4 turns lock-to-lock
Powered by VTEC
Jan 26, 2008 09:03 PM
nexgen91
May 3, 2007 12:39 PM
Civicpmp4
Feb 1, 2004 07:12 PM
