Tune or ECU?
Old Jul 27, 2005 | 06:09 AM
Sahwn's Avatar
Default Tune or ECU?
OK, i have a JDM B18C1 with USDM tranny
MODS:
Comptech Ice box without top of the box gone(cover for filter)
Skunk2 Intake Manifold
Ferra Valve trane
STOCK GSR cams and cam gears
Skunk2 ECU
VAFC(only the RPM is hooked up)
DC Header
ITR Cat
GSR Muffler
I know mix matched all to hell but i bought this car this way. The guy took out the Skunk2 Stage 2 cams. So, now the car is running rich as hell and even throws a check engine light when the O2 senor is saturated.
What to do?
Would getting a new ECU like a chipped P28 be a good idea or should i just tune with the VAFC................I don't know **** about tunning and would have to take it a shop.
Old Jul 27, 2005 | 08:25 AM
drdisco69's Avatar
Default Re: Tune or ECU? (rsg74)
If the ecu is chipped already, I would tune with that. The VAFC is limited in what it can really do.
Old Jul 27, 2005 | 08:51 AM
Sahwn's Avatar
That is what I was thinking. I just need to save up money to buy some Skunk2 Stage 2 cams. Also, I am worried about killing my O2 sensors since i am running rich..........that would just be more money.
Old Jul 27, 2005 | 09:18 AM
mmuller's Avatar
Mad Scientist
by skunk 2 ecu you mean one of those ''skunk'' chips?
generic chips will make you run rich, make that very rich.
just buy a chip with stock specs or midly modified and swap it.
If your running so rich changing cams wont do much for you...
Old Jul 27, 2005 | 10:14 AM
Sahwn's Avatar
Skunk2 ecu.....supposedly. I don't really know. How do i tell? The rev limit is at 9100 RPMS and VTEC kicks in at 6K. The BUTT dyno feels like it ain't making any power after 8K just a bunch of damn noise and the smell of gas!
Old Jul 27, 2005 | 10:31 AM
mmuller's Avatar
Mad Scientist
Default Re: (rsg74)
well, you would not be able to check what the maps look like without an eprom reader; but you can take the ecu cover off and check to see if the eprom is on a socket, if so, you can replace it.
I really would not rev over stock rev limit...wich is 8200. 9100 with your setup is stupid and pointless.
your prolly running ultra rich up that high...specially since your prolly making like 50 pounds of torque
Old Jul 27, 2005 | 11:07 AM
Sahwn's Avatar
ok, i will look into that.
Old Jul 27, 2005 | 07:43 PM
mtber's Avatar
Considering you already have a chipped ecu, you should look into a local uberdata, crome or hondata tuner to tune your vehicle using your chipped ecu.
Or you could look into ordering a good basemap from a reputable tuner
Old Jul 27, 2005 | 11:17 PM
michael O's Avatar
Default Re: Tune or ECU? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Considering you already have a chipped ecu, you should look into a local uberdata, crome or hondata tuner to tune your vehicle using your chipped ecu.
Or you could look into ordering a good basemap from a reputable tuner </TD></TR></TABLE>
I'd suggest tuning it yourself. Check out pgmfi.org for information on tuning. Damn almost all of my posts seem to include pgfmi.org in it.
Old Jul 28, 2005 | 04:15 AM
Sahwn's Avatar
i will look into that too. Thanks. Now the tough part........making the decision! lol
Old Jul 28, 2005 | 06:43 AM
Sahwn's Avatar
not so tough b/c the ECU programming is over my head. But still thinking on getting the ecu reflashed or chipped for stock settings.
Old Jul 29, 2005 | 04:53 AM
Sahwn's Avatar
fond a chip for $30 but i don't know **** about putting it in?
Old Jul 29, 2005 | 05:43 AM
drdisco69's Avatar
Default Re: (rsg74)
http://www.pgmfi.org
Old Jul 29, 2005 | 08:07 AM
Sahwn's Avatar
Ok, since my car is OBD1 does that mean I should just be able to plug the chip in? No soldering? If so then i can do that! Oh, it would be great, if that is the case.
Old Jul 29, 2005 | 02:39 PM
drdisco69's Avatar
Default Re: (rsg74)
I sense a lack of communication here...
http://www.pgmfi.org/twiki/bin...pping
You will have to solder. Or someone can chip it for you. It's really not all that hard if you get the right parts.
Old Jul 30, 2005 | 10:22 AM
Sahwn's Avatar
I am just to chicken to solder my ecu.........I have never solder anything before. Thanks.
Old Jul 30, 2005 | 05:16 PM
mtber's Avatar
Default Re: (rsg74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsg74 &raquo;</TD></TR><TR><TD CLASS="quote">I am just to chicken to solder my ecu.........I have never solder anything before. Thanks.</TD></TR></TABLE>
Your ecu is probably already socketed.....
Old Aug 1, 2005 | 06:54 AM
Sahwn's Avatar
Ok, today i will see what my ecu looks like and post a pic. So, I can end all the wondering.
Old Aug 2, 2005 | 06:37 AM
Sahwn's Avatar
Default Re: (rsg74)
I took some pics and it looks like soldering is required unless i can just flash my ecu..............well i don't know how to do that either:
Old Aug 2, 2005 | 06:51 AM
mmuller's Avatar
Mad Scientist
Default Re: (rsg74)
your going to have desolder and socket that mother
Old Aug 2, 2005 | 07:10 AM
Sahwn's Avatar
NOOOOOOOOOOOOOOOOOOO! NOT ME i will get some one else to do that ****! I ain't ****** it up! lol! I should be able to hold onto the old chip and reuse it right?
bryant382
Mar 6, 2004 05:04 PM
JDM EG2
Mar 10, 2003 03:01 PM
Audipwr1
Oct 16, 2002 08:38 AM
four27
Jul 11, 2002 07:25 PM
Lenthrax
Jun 13, 2002 10:11 AM
