Help car wont start
Old Jul 27, 2005 | 05:21 AM
Adam West's Avatar
Default Help car wont start
92 hatch stock d16 sohc motor. I just replaced the fuel pump.. the car willl turn over but as soon as I give it a little gas it shuts out.. what else could I check??? what else could it be???????/
Old Jul 27, 2005 | 05:22 AM
JDM-EJ1's Avatar
Default Re: Help car wont start (Oclooc)
It could be the main relay, this happened on my brothers DA9. We replaced the main relay and it works great now.
Old Jul 27, 2005 | 05:27 AM
Adam West's Avatar
Default Re: Help car wont start (JDM-EJ1)
where is the main relay located??????????????? also sometimes the fuel pump comes on and sometimes it wont... That was changed to a new one already.......
Old Jul 27, 2005 | 05:32 AM
JDM-EJ1's Avatar
The main relay is located by the ECU up under the passenger side dash.
Old Jul 27, 2005 | 05:33 AM
Adam West's Avatar
are there any diagrams that I can look at?????????
Old Jul 27, 2005 | 06:35 AM
B18C5-EH2's Avatar
Former Moderator
Loved
The main relay on your car is under the dash on the driver's side of the car, near the hood release lever. It is a little box with a big plug going into it, and it has a j-shaped bracket attahced to it held in place with a few 10mm bolts.
Also here's a way to diagnose it:
Turn the key into the "on" position, but do not start the car. Watch as the check engine light goes out, and listen for a "clink" noise from the hood relase lever area (where the main relay is).
If you hear a "click" the car will start, and the main relay is working right then, but if you hear no "clink" then the relay is bad, and you wasted time/money on a fuel pump.
BTW:
What type of fuel pump did you swap in? If you swapped in a new aftermarket one in then I'd swap it out for the old OE honda one - used honda is better than new aftermarket.
Old Jul 27, 2005 | 06:50 AM
JDM-EJ1's Avatar
Default Re: Help car wont start (B18C5-EH2)
Thanks for clearing that up EH2. I thought the main relay was on the other side.
Old Jul 27, 2005 | 07:14 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for clearing that up EH2. I thought the main relay was on the other side. </TD></TR></TABLE>
It actually is on some cars, but in the 1992-1995 Civic it's right by the hood relase area. Also in the DA Integras it's on the driver's side, but further up inside the dash - it's a PITA compared to the EG Civics.
On an EK the main relay is on the passenger side of the dash.
Old Jul 27, 2005 | 07:16 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
On an EK the main relay is on the passenger side of the dash.</TD></TR></TABLE>
Awesome, I knew I've seen it on the passenger side before I believe it was an EK. Thanks for clearing that up.
Brand
21
Sep 8, 2022 09:39 AM
NazVil86
Oct 10, 2006 06:44 PM
confucioussae
Sep 19, 2006 08:05 PM
imoua
11
Jul 28, 2006 08:14 PM
serious
Sep 2, 2002 05:38 PM
