why would a Ex be so slow
Old Jul 27, 2005 | 04:26 AM
matchbox_EK's Avatar
Default why would a Ex be so slow
i have a stock 97 ex coupe:
when i first ran my car with a auto trans it went in the 19's down at the track now that i swaped it over to the 5 speed it still wont get outta tha 18 sec zone-- it feels like when i shift the motor cant keep up
Old Jul 27, 2005 | 04:34 AM
Ricey McRicerton's Avatar
Default Re: why would a Ex be so slow (D-Dot)
Because it's a stock shitbox Civic with 127 hp.
Old Jul 27, 2005 | 04:36 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Well even though the stock 1997 EX is slow, it should at least be in the 17 or even high 16 second range if everything is running right.
Sounds to me like you may have a problem that's slowing the car down even more than usual.
Are you running high 17's or low 17's? Exactly what times are you clicking off?
Old Jul 27, 2005 | 04:45 AM
Default Re: why would a Ex be so slow (B18C5-EH2)
Ah, I had no idea a stock EX was supossed to be faster than that.
Any CELS? You said the car doesn't feel like it can keep up when you shift? What exactly are you experiencing? Stuttering? Hesitation?
Old Jul 27, 2005 | 05:02 AM
Default Re: why would a Ex be so slow (Ricey McRicerton)
not runnin past 18.o1-- it really dosent hesitate or do anything of that matter it just dosent pull its weight-- i think the motor is dead with 145k
i also have a 97 hatch and when i had the y7 motor i was running mid16 all day
Old Jul 27, 2005 | 05:03 AM
litterbox's Avatar
I am a (Trial User) Army
Wheel/Tire size?
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Ah, I had no idea a stock EX was supossed to be faster than that.
Any CELS? You said the car doesn't feel like it can keep up when you shift? What exactly are you experiencing? Stuttering? Hesitation?</TD></TR></TABLE>
Yeah, do you keep up on routine maintenance? Give us more information so we can help you.
Old Jul 27, 2005 | 05:04 AM
Default Re: why would a Ex be so slow (JDM-EJ1)
Have you changed your cap/rotor/plugs/plug wires lately? How about your fuel filter? Don't a leakdown and compression test yet?
Old Jul 27, 2005 | 05:11 AM
BauleyCivic's Avatar
Risky Business
Because VTEC doesn't make a car faster?
i have si rims on the car now--- but Ricey i do need to check the routine maintenance on the car i got it 2 months ago from some young *** girl who just knows how to press the gas pedal
Old Jul 27, 2005 | 05:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Dot &raquo;</TD></TR><TR><TD CLASS="quote">i have si rims on the car now--- but Ricey i do need to check the routine maintenance on the car i got it 2 months ago from some young *** girl who just knows how to press the gas pedal</TD></TR></TABLE>
Sounds to me like there could be something fundamentally wrong (low compression, fried rings, etc) and that's why it just feels slow. Also, if your ignition components are all old and worn out, that can make a world of difference too.
Old Jul 27, 2005 | 05:21 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Dot &raquo;</TD></TR><TR><TD CLASS="quote">not runnin past 18.o1-- it really dosent hesitate or do anything of that matter it just dosent pull its weight-- i think the motor is dead with 145k </TD></TR></TABLE>
Did you install a new clutch when you swapped in the 5-speed? If not then the clutch may be slipping, allowing power to slip away rather than hit the axles/wheels/ground.
Also what other accessories are on the car that can add weight? your times may be fine for the weight if it's got a booming stereo, etc.
Did you weigh the car?
Old Jul 27, 2005 | 05:22 AM
JDM-EJ1's Avatar
I would take the car to a mechanic to get some maintenance done on it, such as cap and rotor, spark plugs, spark plug wires, and possibly he could figure out what's wrong. Or, do the work yourself if you know how.
Old Jul 27, 2005 | 05:31 AM
litterbox's Avatar
Get a helms manual and start diagnosing this problem yourself. From there, the sky is the limit.
http://www.helminc.com
Old Jul 27, 2005 | 05:49 AM
Default Re: why would a Ex be so slow (litterbox)
i got new clutch new axles
Old Jul 27, 2005 | 06:18 AM
flood's Avatar
Default Re: why would a Ex be so slow (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Because VTEC doesn't make a car faster?</TD></TR></TABLE>
It doesn't? Sure helps it pull to 7k
I think your times are a bit slow, but like others have said it could just be some reg mant items that have been over looked. Granted my D16Y8 isn't fast my any means but it doesn't feel bogged down or anything.
Old Jul 27, 2005 | 06:20 AM
litterbox's Avatar
Default Re: why would a Ex be so slow (flood)
Bauley is anti D v-tech y0!
Old Jul 27, 2005 | 06:40 AM
flood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Bauley is anti D v-tech y0!</TD></TR></TABLE>
Ohhhh well that explains it. Well I would rather have it than not.
Old Jul 27, 2005 | 07:13 AM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote">
Ohhhh well that explains it. Well I would rather have it than not. </TD></TR></TABLE>
Hell yeah! I got's the mAd VtAc waiting in my shed. Totally rebuilt and ready to be put to the test (after break-in). It is ready for turbo, but my wallet isn't . Soon it will have a turbo, but it's a little way's down the road. Oh, the vtec does make it faster and so does the extra .1L. It may not sound like much, but when your only dealing with 1.XL's it makes a difference .
Old Jul 27, 2005 | 07:29 AM
Risky Business
No bolt-on SOHC VTEC motor "pulls." Trust me. Unless you bolted a turbo onto it.
Old Jul 27, 2005 | 07:42 AM
B18C5-EH2's Avatar
Former Moderator
Loved
No bolt-on SOHC VTEC motor "pulls." Trust me. Unless you bolted a turbo onto it.</TD></TR></TABLE>
Come on now, "pulls" is totally subjective. I believe my SOHC non-VTEC "pulls" very well considering it ran dead even with my wife's old B16A2-swapped 1992 Si HB.
Old Jul 27, 2005 | 07:44 AM
nota-eg's Avatar
Plugs and wires can make a world of a difference. I just swapped mine after a year and it feels better.
Pull the valve cover off and see if there is any buildup in there. I had one motor, there was a lot of sludge buildup. My new motor w/ over 220k looks pristine.
You said you got the car from a young girl. My experience with most young girls is that they think that it'll run forever as long as there is gas in the tank. I'd get the motor maintenanced just like everyone else said.
Old Jul 27, 2005 | 07:48 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Your P29's are not "bolt on"
Old Jul 27, 2005 | 07:52 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Ahh, but I started without VTEC! I was at a 20hp disadvantage to my D16Z6/Y8 brethren!
