B16 head on GSR block?
Old Jul 26, 2005 | 08:57 PM
3gsi's Avatar
Default B16 head on GSR block?
I've searched for the answer but cannot find the it. I have a 95 LS and I'm going to put a new motor in it. I'm about to buy a GSR block with an ITR crank and eagle rods, and I'm going all-motor. I'm going to put ITR pistons in it also. I need help deciding which head to use, b16 or GSR. Can I use the b16 head off a 00si? I'm not sure if the sensors will work since its obd2 and my car and the block is obd1. Or would I be better off using a GSR obd1 head? Thanks for the help
Old Jul 27, 2005 | 09:22 PM
Hapexamendios's Avatar
Default Re: B16 head on GSR block? (3gsi)
gsr will slightly up the compression but im told the gsr intake manifold sucks
Old Jul 28, 2005 | 05:15 PM
TypeSLR's Avatar
the only things that you ahve to worry about with obd1 and obd2 are the wiring harness, the dizzy, the fuel injectors, and things like that, the years of the blocks and heads do not matter, as long as they are in working order.
Old Aug 6, 2005 | 05:09 PM
LiL MaN213's Avatar
B A N N E D
Default Re: B16 head on GSR block? (TypeSLR)
yo i got a jdm b16 head if u want it let me know
allstarr7
Jan 11, 2009 03:17 PM
3gsi
Jul 27, 2005 08:43 PM
aser1z
Apr 25, 2005 01:17 PM
.ShawnD.
21
Jul 17, 2003 08:15 PM
CBR
Aug 19, 2002 07:18 AM
