Getting Pr4 w/vtec to engage vtec correctly
Well I got my pr4 chipped for vtec (obdo) but we are having problems figuring out how to wire up vtec.
I believe the connector pin is B3 that plugs into the ecu. It is orange and red (I think off the top of my head/color blindness).
We traced it but it leads into the engine harness
In order for vtec to be chipped in, removal of a/c was needed
so we awesome this wire has to do with the a/c but so far it leads to no A/C components
If anyone has sucessfully put a pr4/vtec obdo and used it correctly on a mini-me could you post up how you got vtec to work.
-Shane
.In order for vtec to be chipped in, removal of a/c was needed
-Shane
ill try and find out for you. i don't do electrical. im running the same ecu on my d15b and it works. i don't know if its any different, but isnt the vtec wire into the ecu green?
this pr4 is originally from a 90-91 Integra obd-O. It did not come with vtec. It is pretty much a pm6 but a little different. I am not sure what green wire you are talking about. I am not a computer guy or a electrically guy but looking at these schematics I am getting better
yes i know its originally the older tegs. i had mine chipped for vtec.
i sent the link to the guy that does all my electrical crap, hopefully he takes a look for ya.
just trying to help you out. i went out and checked my ecu/wiring
and from what i could see, there isnt any orange/red wires. i found a bunch of red/yellow and a couple red/black wires though.
there's a few wires that have been tapped into, im not quite sure what they do though.
havn't heard back from the guy yet, but soon as i do, ill let ya know.
Yeah usually the wire goes to the a/c clutch relay,,then you put the wire from the relay to the vtec solenoid....If you dont have any of that a/c stuff at all then just run the wire from ecu to an automotive 5way 30amp
Also Im pretty sure that its A13 for the 12v signal..
Ryan Arnold
May 7, 2016 05:54 PM
jetoutant
11
Jan 2, 2008 07:50 PM
