gsr tranny or b16 tranny for turbo??
Old Jul 26, 2005 | 05:42 PM
eg:R's Avatar
Default gsr tranny or b16 tranny for turbo??
i have both tranny and just wondering which one will be better off with> was thinking about the gsr one.. will be running on a built lsvtec gt30 turbo
Old Jul 26, 2005 | 06:19 PM
s2kdre's Avatar
Default Re: gsr tranny or b16 tranny for turbo?? (eg:R)
both are great, how high are u revin?
Old Jul 26, 2005 | 06:32 PM
eg:R's Avatar
8-8.5k rpm
Old Jul 26, 2005 | 06:41 PM
swoyEKr.'s Avatar
The b16 gears are a little short depending on where you plan to make power, i'd go with the gsr because its not too short and not to long and it pulls decent, just my .02
Old Jul 26, 2005 | 07:19 PM
1700anddroping's Avatar
Default Re: (Quick 99)
i would do gsr w/a ls 5th .comes in handy for those long road trips on the i/s.
harv
Old Jul 26, 2005 | 07:25 PM
murtnabila's Avatar
Default Re: (1700anddroping)
gsr. Most get b16 and then get taller tires to prevent slipping so don't make any sense to me?
Old Jul 26, 2005 | 07:32 PM
Default Re: (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">gsr. Most get b16 and then get taller tires to prevent slipping so don't make any sense to me?</TD></TR></TABLE>
your right that does not make since what so ever.who wants to run out of tranny before turbo.
harv
Old Jul 26, 2005 | 07:59 PM
nfn15037's Avatar
I run Si/ITR gearing and I love it. 366 whp and no traction issues (not any more than I woul dhave w/ a GSR gearbox) and the highway RPM is fine even on 195/50/15 tires. FWIW my fuel mileage is 100% the same between the ITR and GSR gearing.
Old Jul 26, 2005 | 08:21 PM
beerbongskickass's Avatar
What you said makes no sense to me...
You have to look at a lot of things when choosing a tranny, but no matter what you go with... shorter gears will make your car accelerate faster and bigger tires will give you more traction.
Old Jul 26, 2005 | 08:29 PM
jDMJeRk's Avatar
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
You have to look at a lot of things when choosing a tranny, but no matter what you go with... shorter gears will make your car accelerate faster and bigger tires will give you more traction. </TD></TR></TABLE>
WIDER tires 225's !
Old Jul 26, 2005 | 08:43 PM
SHystrdyGSRtdy's Avatar
Default Re: (jDMJeRk)
wider rims. 8"
Old Jul 27, 2005 | 08:06 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (SHystrdyGSRtdy)
i love my gsr trans on my setup, plan on hitting mid 300 to 400 whp
revving at 4000 rpm on the highway at 80mph is my only problem
Old Jul 27, 2005 | 07:09 PM
murtnabila's Avatar
agreed...but correct me if I'm wrong most turbo set ups do run bigger tires to help out the traction problem. So for those that do and have b16 tranny why not run a gsr tranny instead of a b16?
Old Jul 27, 2005 | 07:19 PM
ultimately unless you run out of 5th gear in the 1/4 mile you should run the shortest transmission as possible, while the b16 n type r trans do this, they also make getting traction that much harder which is where the gsr trans could possibly help,
all b series transmissions first 2 gears are basically the same, its the 3rd 4th and 5th that are longer/shorter
for all out drag a b16 or itr trans is the best option, but for a daily driver and weekend warrior id say the gsr transmission is the best choice
Old Jul 27, 2005 | 08:17 PM
blackeg's Avatar
Default Re: (coptzer)
i think the gsr tranny will be better than the b16.
Old Jul 27, 2005 | 09:18 PM
randys's Avatar
race-lines.com
i love my b16 tranny. i think its more of a preference.
Old Jul 27, 2005 | 11:21 PM
ay_dawg's Avatar
Both will be good choices.
Old Jul 28, 2005 | 02:11 PM
astig* DC2's Avatar
Default Re: (Paolo)
JDM ITR TRANNY....thats perfect...esp w/ lsd....
Old Jul 28, 2005 | 06:17 PM
Default Re: (k4SP3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k4SP3R &raquo;</TD></TR><TR><TD CLASS="quote">JDM ITR TRANNY....thats perfect...esp w/ lsd.... </TD></TR></TABLE>
I would rather have a Quaife LSD than an OEM...
EGLUVN
51
Aug 21, 2007 09:41 AM
tomlinson619
Jun 2, 2006 01:58 PM
alloysr16s
133
Feb 6, 2006 12:06 PM
locoSIR20
Feb 1, 2005 05:53 PM
92-EG6
30
Mar 14, 2004 06:18 AM
