Samco hose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">work better than oem
got mine at http://www.passwordjdm.com</TD></TR></TABLE>
how so?
how so?
i was also considering gettting these along with a new fan switch and thermostat. cant see how the hoses will "work better" than OEM though. Better quality YES but work better.......how will you be able to tell that?
To help this thread out I will ad to it with this:
The SAMCO Sport silicone hoses will not "work" better. It is not like the inside is coated with some magic substance that makes the coolant flow with less restriction!
The main point to upgrading to the silicone hoses is that they will be better suited to the higher pressures and temperatures which come from motors that have been modified or, that are working passed the limits for which it was built to withstand from the factory.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AGS »</TD></TR><TR><TD CLASS="quote">To help this thread out I will ad to it with this:
much better explanation. i wanted them before and may just get em now
</TD></TR></TABLE>much better explanation. i wanted them before and may just get em now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddydc5 »</TD></TR><TR><TD CLASS="quote">So is it safe to say that it will keep heat in better then the factory hoses????</TD></TR></TABLE>
It is not about keeping heat in or out, that is not the job/function of the radiator hoses. The radiator, cooling fans and type of coolant are going to be the main players in the temperature of your coolant.
Nocturnal
13
Dec 7, 2004 06:04 PM
