Jackson Racing Map Controller need info??
Old Jul 26, 2005 | 07:24 AM
vipps's Avatar
Default Jackson Racing Map Controller need info??
Anyone using this Jackson Raing Map Controller? How does it work after install, do I need to adjust anything? Mine is B18C5 NA Please help???
Old Jul 26, 2005 | 07:57 AM
Mythias's Avatar
Default Re: Jackson Racing Map Controller need info?? (vipps)
Uhm... if your car is NA, then why on earth would you want the JR map sensor controller?
Old Jul 26, 2005 | 08:22 AM
vipps's Avatar
Default Re: Jackson Racing Map Controller need info?? (mythias)
it's not helping anything for NA? I don't understand how's it actually work. please advise
Old Jul 26, 2005 | 08:24 AM
Spunkster's Avatar
IT should only be used with a boosted application. If you don't hav ea supercharger or turbo, then you are wasting your time and hurting performance.
Old Jul 26, 2005 | 02:14 PM
92TypeR's Avatar
FSAE
Default Re: Jackson Racing Map Controller need info?? (Spunkster)
Isn't it just a chipset that alters the MAP signal so you can run higher than ~11psi, which is what the OEM MAP is good to? Kind of like running a 3-Bar MAP, it just allows you to run higher boost levels without throwing a CEL or fuel cut.
Old Jul 27, 2005 | 08:56 AM
Spunkster's Avatar
Default Re: Jackson Racing Map Controller need info?? (92TypeR)
No, it prevents the ecu from seeing boost completely.
rorik
Jan 23, 2006 06:27 PM
jbs
Feb 19, 2004 07:54 AM
99simass
Oct 8, 2001 11:52 AM
