ACCELERATION VIBRATION
i have a 92 da teg and its lowerd new dss axles, full race traction bars poly mount inserts the motor is tight in there , and my front end parts are ok but i cant get rid of a vib i get in 2nd and 3rd around 2k to 3k rpm under a load its not everytime sometimes worse than others ne ideas im all out? i know its not axles 3rd set ?
might be your intermediate shaft, i just had a vibration on my car too, couldnt figure it out till today, i changed my passenger side axle and got rid of it. (passenger side was a brand new axle too before i changed it) just shitty i guess
I thought my vibration problems were from a diff bearing failure, so after pulling the tranny and seeing that the diff bearings were fine, I figured it was my diff itself. I purchased a low mileage unit and reinstalled it, too bad when I pulled the tranny gears out, they fell all apart and I had to take an hour getting all the gears and sincros and forks back together, lol. The experience was great tho, first tranny work on my part. All went well and when everything was back together, I couldn't get the rear mount bracket bolts back in, matter of fact, the two of the rear mount bolts werent there when I dropped the tranny, one on both sides.
Well, the vibration ended up being my driver's side driveshaft because the inner joint was getting torn up due to the aweful angle the rear mount was allowing to occur on the driveshaft. I replaced the rear mount bolts with new ones and replaced the driver's side driveshaft, and all is well again. No vibration finally. And when I say vibration, I mean when accelerating, the whole car shook vilently, but when maintaining a speed or decelerating, no vibrations at all.
