LS TURBO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nxda9 »</TD></TR><TR><TD CLASS="quote">Does anyone know how to tap a block for an oil feed line
flamenco-t makes a kit for oil supply to the turbo. it has a tee that runs off the back of the block so you dont have to tap the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NuclearB18B »</TD></TR><TR><TD CLASS="quote">flamenco-t makes a kit for oil supply to the turbo. it has a tee that runs off the back of the block so you dont have to tap the block.</TD></TR></TABLE>
how much is that kit, bc picking up a spare oil pan and fitting isnt expensive at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsvtecBoi408 »</TD></TR><TR><TD CLASS="quote">for stock ls.... u can boost the is 8.. but u can boost much higher if u can find a hella good *** tunnner..</TD></TR></TABLE>
i think 17psi was the most ive seen on a stock block ls. then again it was only one dyno pull so that doesnt prove its safe...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater »</TD></TR><TR><TD CLASS="quote">i think 17psi was the most ive seen on a stock block ls. then again it was only one dyno pull so that doesnt prove its safe...</TD></TR></TABLE>
17psi safe??? hardly. id like to say 12 psi, but majority of people ive encountered suggest 10
From what I've been reading, 300 whp is the limit (w/ tuning).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional »</TD></TR><TR><TD CLASS="quote">
how much is that kit, bc picking up a spare oil pan and fitting isnt expensive at all</TD></TR></TABLE>
he sells an oil feed kit and an oil return kit as well, pm him for prices, or look in the forced induction sponsor sale thread.
almostboostedgsr
Feb 7, 2007 01:35 PM
