oil T fitting (searched)
Old Apr 11, 2006 | 07:40 AM
turboH22Aakkord's Avatar
Default oil T fitting (searched)
ok, ive got the typical home made oil "t" on the back of my block.. and im going to change that and put the T on the fire wall.. a while back i found an adapter piect that screwed in to the block but also had like 2 1/8 or 1/4 wholes on it as well.. i cant seem to find this piece now though! can someone help? thanks guys
Old Apr 11, 2006 | 07:51 AM
adictionbass's Avatar
Default Re: oil T fitting (turboH22Aakkord)
if you want to remote mount everything to the firewall you will need:
1/8" to -3 an adaptor
~12-14" -3 an line with fittings
1/8" 3 way fitting
2 more 1/8" to -3 an adaptors
this will give you a t mounted on the firewall with one 1/8" port for either your stock or aftermarket oil pressure gauge/switch and one -3an feed for your turbo.
Old Apr 11, 2006 | 08:44 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboH22Aakkord &raquo;</TD></TR><TR><TD CLASS="quote"> a while back i found an adapter piect that screwed in to the block but also had like 2 1/8 or 1/4 wholes on it </TD></TR></TABLE>
sounds like your talking about the tuner toys fitting. http://tunertoys.zoovy.com/product/OTODK
Old Apr 11, 2006 | 09:08 AM
Default Re: oil T fitting (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">
thats the ticket!!! thanks man!
Old Apr 11, 2006 | 09:10 AM
if your using that, why are you putting a T on the firewall?
Old Apr 11, 2006 | 09:30 AM
Default Re: oil T fitting (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">if your using that, why are you putting a T on the firewall?</TD></TR></TABLE>
well im boosted ... and i have an aftermarket oil pressure sensor... and i just want to use that tuner toys one so that i dont have to relocate my stock sensor and then ill just run the aftermarket sensor off of the t on the fire wall and the oil feed from that T as well.. i just think that fiting from them would be stronger then the t right off the block... am i wrong?
Old Apr 11, 2006 | 12:01 PM
dpetro1's Avatar
yeah the fitting is def a better idea then the regular brass tee setup. but i think what addiction is saying is that you could just have a line coming from the block to the tee on the firewall and then run the feed line, aftermarket oil sensor, and stock oil sensor all off that tee. for that setup you wouldnt need the TT fitting.
but from what you described your gonna run the TT fitting, have one port for the feed line and the other port is gonna have a line that runs to the remotely mounted aftermarket oil sensor on the firewall, right? that will work just fine too.
Old Apr 11, 2006 | 12:05 PM
Frozen E's Avatar
H-T White Ops
tunertoys
Old Apr 12, 2006 | 10:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah the fitting is def a better idea then the regular brass tee setup. but i think what addiction is saying is that you could just have a line coming from the block to the tee on the firewall and then run the feed line, aftermarket oil sensor, and stock oil sensor all off that tee. for that setup you wouldnt need the TT fitting.
yep, that exactly it...i think haha.. i just didnt want to have to extend the stock oil pressure sensor wire.. but thats not all that big of a deal i guess.. so i might just do that.. thanks guys
aryiman98civic
Sep 23, 2006 08:04 PM
Boosted Chemist
Aug 4, 2005 09:36 PM
integra-modder
Jul 7, 2004 08:19 AM
