attn:higher mileage R owners. check your oil pan bolts.!!
Old Jul 25, 2005 | 04:15 PM
baonest's Avatar
Default attn:higher mileage R owners. check your oil pan bolts.!!
well, a 20 min oil change took me a little over an hour today.
i got under the car, saw some oil, and checked the oil pan bolts, well i was missing one nut, one bolt, and about 3-5 different ones were loose (not real loose, but they use a goood tightening). its odd, i never noticed a loss in oil either. i even had to take the tranny brace off and tighten one under there.
oh and i found out the right side header stud is snapped off. oh well, ill put some RTV on it later.
what made me check them was when i put a 100K mile motor into my other integra, i noticed one of the oil pan bolts was missing. so i figured hell, might as well check the R
check your bolts people.
Old Jul 25, 2005 | 04:22 PM
Nishant's Avatar
Default Re: attn:higher mileage R owners. check your oil pan bolts.!! (baonest)
don't have a R but will check mine next time i do an oil change
Old Jul 25, 2005 | 04:24 PM
baonest's Avatar
Default Re: attn:higher mileage R owners. check your oil pan bolts.!! (Nishant)
good deal. doesnt hurt to check them on any mileage car
Old Jul 25, 2005 | 05:04 PM
01usjdmr's Avatar
That is pretty common on high mileage hondas with the rubber oil pan gaskets. They harden and shrink up.
Old Jul 25, 2005 | 05:05 PM
baonest's Avatar
Default Re: (01usjdmr)
yeah, i remember people mentioning it.
my R has 122K on it.. bought it at 117K. so i have to go around making sure things are gooood.
Old Jul 25, 2005 | 05:39 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (baonest)
they're tricky bolts
you can't tighten it too much or the rubber will come out of the groove and you will get a leak from the oil pan gasket
just toque it to specs with some crazy silicone
Old Jul 25, 2005 | 05:52 PM
Bbasso's Avatar
Default Re: (MugenHonda)
Mine were finger loose at 50k
Old Jul 26, 2005 | 02:21 AM
Chris93Si's Avatar
Had one missing @ 58k when I bought my car. Good thing to check people
Old Jul 26, 2005 | 02:53 AM
#1151's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i remember people mentioning it.
my R has 122K on it.. bought it at 117K. so i have to go around making sure things are gooood. </TD></TR></TABLE> 86k here
Old Jul 26, 2005 | 04:04 AM
Dave_B's Avatar
Ok now I'll go check, don't want to loose oil in this thing.
Fred Dukes
Apr 29, 2017 02:48 PM
thurmondauto
Jun 22, 2009 10:51 AM
gosu08
Apr 23, 2009 12:55 PM
civiccpedx
Oct 19, 2004 01:27 PM
GSRwBOOST
Jun 25, 2001 06:05 AM
