You guys void your warranty's?
Old Jul 25, 2005 | 12:16 PM
pushinlsteg's Avatar
Default You guys void your warranty's?
I really want to get a new type S...but I'm gonna feel like its pointless if I can't even lower it, or modify it in any way....
So, seeing as the cars came out in 2002, they probably still have warranty's on them, did you guys just modify them without giving a ****?
let me know...thanks
going from a turbo LS to a stock type S is a downgrade to me...
Old Jul 25, 2005 | 12:44 PM
Blaziniflo's Avatar
Default Re: You guys void your warranty's? (pushinlsteg)
just mod it
Old Jul 25, 2005 | 06:27 PM
EP3tune2RULE's Avatar
who cares about the warantty, its a HONDA!
Old Jul 25, 2005 | 06:52 PM
Auex's Avatar
Default Re: You guys void your warranty's? (EP3tune2RULE)
The magnusson moss act may have some info that may help you as far as the warranty. Basically you can add things to your car, but if there is a problem that is not directly caused by the part added then it then the dealer cannot void your warranty. However if the part was the problem then you pay for the repairs, they are not covered under warranty. There are alot of issues regarding audio and electronics that are commonly misdiagnosed and then the warranty is still covered. So basically it installed correctly then it will not void your warranty. If you are seriously worried add only things the dealer sells and installs.
I can directly link to a copy of the document if so required.
Old Jul 25, 2005 | 09:45 PM
Shingo's Avatar
I care about warranty,so i didnt mod the engine.
Old Jul 25, 2005 | 10:14 PM
Corbic's Avatar
Default Re: (Shingo)
You still have a warrenty as long as the part added did not cause the malfuntion. Thus if you lower your car and blow your headgasket, there is no corolation. If you add a Air-intake and exhaust and your 5th gear blows... there is no corolation... or is there? This is where a good dealer comes in. Good ones will not care and fix it, bad ones will nit-pick.
Remember, dealer is not loosing money for fixing warrenty issues, in fact they make money doing it. Honda pays the dealer to fix the part.
Old Jul 26, 2005 | 12:04 PM
this is basically all I want until my warranty is up...
intake, header, exhaust, lowered. maybe a lip and a spoiler.
Am I going to be in trouble with those few things...?
Old Jul 26, 2005 | 12:16 PM
Corbic's Avatar
Header will give your problems. Cat-back CAN NOT hurt your car, intake they would be hard pressed for an argument, Lowering will only F-up you suspension and handeling, not your power-train.
Old Jul 26, 2005 | 12:34 PM
Shingo's Avatar
you can change to stock intake when you take it to the dealer. No TUNE ,NO LIFE Warranty cant stop us
Modified by Shingo at 6:37 PM 7/26/2005
Old Jul 26, 2005 | 01:13 PM
Gospeedgo's Avatar
Just do it, really doesn't matter if you want to mod it
Old Jul 26, 2005 | 05:23 PM
03nbpRsx's Avatar
I just went for it.
Old Jul 26, 2005 | 07:23 PM
eMpAtHy's Avatar
Default Re: (03nbpRsx)
it's not hard to put the stock intake box back on...
Old Jul 26, 2005 | 07:34 PM
I don't mind working on **** at all...there was a point where I had to readjust my exhaust, and take the downpipe off my LS every other week to fix some things.
If I had to take it back to the dealership, I'd convert everything back over to stock engine wise....doing that kind of work is no problem for me. I'm just wondering if they would notice that it had been changed back and forth.
Old Jul 27, 2005 | 11:47 PM
Azcheron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">I don't mind working on **** at all...there was a point where I had to readjust my exhaust, and take the downpipe off my LS every other week to fix some things.
If I had to take it back to the dealership, I'd convert everything back over to stock engine wise....doing that kind of work is no problem for me. I'm just wondering if they would notice that it had been changed back and forth.</TD></TR></TABLE>
It doesnt matter
intake doesnt affect warranty in anyway
exhaust doesnt either
springs wont either, unless u break a CV boot or something ghey!
i brought my R to Acura with 49,950 miles on it, i had 50 miles left on warranty and my car had springs, shocks, intake, spark plugs, fuel pump, and a few more things and acura replaced my tranny synchros after a test drive of grinding gears
light mods wont affect ur warranty, header might though
just mod it, just dont do anything crazy
Old Jul 28, 2005 | 04:01 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: (Corbic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corbic &raquo;</TD></TR><TR><TD CLASS="quote">Remember, dealer is not loosing money for fixing warrenty issues, in fact they make money doing it. Honda pays the dealer to fix the part. </TD></TR></TABLE>
Be careful. The dealer's service department is paid at a drastically reduced rate for warranty work.
Basically, the dealer and the manufacturer are splitting the cost of warranty work, so it's not a good deal in any way for the guy who's selling cars.
Honda/Acura does this in order to avoid dealer service departments participating in extra-work scams and charging them as warranty issues. It could be a big problem in some heavily metropolitan areas of the USDM.
Old Jul 28, 2005 | 05:35 AM
giff74's Avatar
Default Re: (George Knighton)
I planning on voiding mine bit by bit. First suspension, then a drop in and exhaust, then header and Hondata and finally Jackson or a turbo. By the time I convince my wife to let me spend the money on these different things my warranty will be up anyway. I like to have warranty for the small things: leaky sunroof, or window regulator. I am not overly worried about the power train in a Honda.
Old Jul 28, 2005 | 06:01 AM
acurate's Avatar
Default Re: (giff74)
two words: Magnusson Moss
Old Jul 28, 2005 | 08:59 AM
coupe99vtec's Avatar
the only way they wold be able to tell if u take intake on and off (like my friend) is they see marks all over the screws that you ahve to unscrew and screw back on all the time
Old Jul 28, 2005 | 09:52 AM
HondaNINE's Avatar
my intake and headers were covered by honda, bacause they sold them to me and instailed them.
Old Jul 28, 2005 | 11:03 AM
Nosser's Avatar
Default Re: (HondaNINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">Be careful. The dealer's service department is paid at a drastically reduced rate for warranty work.
Exactly. Dealers do not want to do warranty work if they don't have to, service departments make their money on cash customers. Can an intake void your transmission warranty....no. BUT, trans problems can be excluded from warranty coverage if the dealer says the problems are due to abuse, and modifications that increase horsepower can strengthen their case. It really varies from dealer to dealer...some are very reasonable, others are terrible.
Old Jul 28, 2005 | 05:55 PM
ian04rsx's Avatar
everyone is saying that a new header voids your warranty, but it doesnt. when i put mine on (strup performance 4-1 header), I checked to make sure it wouldnt void anything. They told me as long as your header doesnt crack everything else that honda put on it is covered weather it could possible be caused by the modifiaction or not.
Old Jul 30, 2005 | 01:13 PM
rbsteven's Avatar
Default Re: (ian04rsx)
Just got back from an Acura dealership, I'm in the process of maybe getting a 05 RSX w/ 2 miles on it. I talked to them about modding the car and what my warranty will cover. They are one of the bigger Acura dealerships here and they said if they install the part it is covered under warranty.
Old Jul 30, 2005 | 04:03 PM
Nosser's Avatar
Default Re: (rbsteven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian04rsx &raquo;</TD></TR><TR><TD CLASS="quote">everyone is saying that a new header voids your warranty, but it doesnt. when i put mine on (strup performance 4-1 header), I checked to make sure it wouldnt void anything. They told me as long as your header doesnt crack everything else that honda put on it is covered weather it could possible be caused by the modifiaction or not.</TD></TR></TABLE>
Huh? Something about crack....
Old Jul 30, 2005 | 06:17 PM
05naep3's Avatar
i have 05 ep3 put tein ss on mine it voided the suspension part of the warranty. waiting for 3yrs or 36,000 miles sucks too long of a wait. do what u want feel though.
Old Jul 31, 2005 | 03:11 PM
rotflmao's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">I really want to get a new type S...but I'm gonna feel like its pointless if I can't even lower it, or modify it in any way....
going from a turbo LS to a stock type S is a downgrade to me...</TD></TR></TABLE>
Go for it. Integras ride like dog poop in comparison.
Mod it. If you have the brains to mod the car yourself, then you can step up and fix the car yourself when it has a problem.
Death_to_Thieves
Acura TL, RL & ZDX
Jan 5, 2010 01:39 PM
Frator
Jan 18, 2007 10:21 AM
Ruamit
Acura TL, RL & ZDX
11
May 9, 2005 08:31 PM
SuperRice
Jun 23, 2002 01:04 AM
