TOO hot need AC help D-series to B-series
Old Jul 25, 2005 | 12:15 PM
gato5254's Avatar
Default TOO hot need AC help D-series to B-series
Hey guys i have a 96 cx hatch with a type R swap but i have a problem i took out my ac system and was wondering if i could use every thing from the D-series AC system for the B-series to have AC. thanks
Old Jul 25, 2005 | 12:32 PM
96hatch96's Avatar
Default Re: TOO hot need AC help D-series to B-series (gato5254)
yea, it should fit, I used everything from my old swap, but the only thing is that the ac compressor will only bolt up to 2 of the 4 holes. It will stay though. Get the ac belt for the b18c5 to fit.
Old Jul 25, 2005 | 12:45 PM
93Civac's Avatar
Get the ac bracket from a 97 honda crv and it will bolt to the engine and the d series ac compressor will bolt up with all four bolts, no problem. You can get the bracket from Honda for about $75.
Old Jul 25, 2005 | 01:09 PM
gato5254's Avatar
Default Re: (93Civac)
thanks for your help guys
Old Jul 25, 2005 | 06:46 PM
96hatch96's Avatar
Default Re: (gato5254)
If you already have the B-Series bracket from the type r on there, why spend $75, when you can bolt on the D series compressor and 2 bolts will hold it. I've had mine on for over 2 years, and it never got loose.
Old Jul 25, 2005 | 06:58 PM
eg crunkmonster's Avatar
Default Re: (96hatch96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96hatch96 &raquo;</TD></TR><TR><TD CLASS="quote">If you already have the B-Series bracket from the type r on there, why spend $75, when you can bolt on the D series compressor and 2 bolts will hold it. I've had mine on for over 2 years, and it never got loose.</TD></TR></TABLE>
you are one of the lucky ones then, because more than likely, those two bolts will snap. Ive seen it happen a lot of times. Anyways, get a 97 CRV bracket pn: 38930-P7J-000. This is a good honda site http://www.slhonda.com/orderparts.jsp or http://www.hondaautomotiveparts.com
Old Jul 25, 2005 | 07:03 PM
xEnderx's Avatar
Because that is a risky way to do it. I'd drop the money on a correctly patterned bracket.
hondab1015
Jun 26, 2015 07:46 AM
vietguy
Sep 26, 2006 11:52 PM
sooboss
20
Sep 13, 2004 02:13 PM
Ehron
Jan 4, 2003 05:13 AM
