smoke when i hit vtec.
Old Jul 25, 2005 | 12:00 PM
Andrewm224's Avatar
Default smoke when i hit vtec.
I get massive black/grey smoke when i hit vtec and i really step on it while im in vtec.... I thikn it might be my rings but i want some other peoples opinions.... thanks in advanced... I am running ls/vtec too btw...
Old Jul 25, 2005 | 12:01 PM
temp's Avatar
Default Re: smoke when i hit vtec. (Andrewm224)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrewm224 &raquo;</TD></TR><TR><TD CLASS="quote">I get massive black/grey smoke when i hit vtec and i really step on it while im in vtec.... I thikn it might be my rings but i want some other peoples opinions.... thanks in advanced... I am running ls/vtec too btw...</TD></TR></TABLE>
what is your current fuel management setup? what cams are you runnin?
Old Jul 25, 2005 | 12:04 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: smoke when i hit vtec. (temp)
some smoke is normal, how about doing a compression or leak down test?
Old Jul 25, 2005 | 12:39 PM
1badcrx's Avatar
small amounts of smoke are common, but it could also be your fuel management system
Old Jul 25, 2005 | 11:06 PM
Andrewm224's Avatar
stock gsr cams.... but i am talking alot of smoke running rich is an understatment
Old Jul 26, 2005 | 12:18 PM
jay_c's Avatar
Default Re: (Andrewm224)
If youre not noticing any sign of power loss its probably not your rings, definetly would do a compression test anyway, but I think maybe it could be your vtec solenoid. Only cause I had the same thing happen to my integ and that was the fix. Also check and make sure oil is not leaking into the spark plug tube that may cause it too.
Old Jul 26, 2005 | 03:52 PM
Andrewm224's Avatar
yeah i think it is my vtec solenoid cuz that was one of the things that came up when i checked the cel... thanks
cam003
Aug 5, 2007 10:34 AM
Seraph
Nov 11, 2006 05:27 AM
black em1
Feb 12, 2005 07:48 PM
lsvtec101
Dec 8, 2004 06:07 AM
black_rude_lude
Mar 31, 2004 03:40 AM
