switch to synthetic oil?
Old Jul 25, 2005 | 09:04 AM
cbmprelude's Avatar
* B A N N E D *
Default switch to synthetic oil?
If I want to switch over to synthetic oil, when previously have regular, what needs to be done more than a standard oil change? Do need any sort of hot oil flush to get any remaining regualr oil out? I was planning after switching the oil to change it about every 7500 miles. Any advice thanks.
Old Jul 25, 2005 | 09:19 AM
AccordTunr's Avatar
Default Re: switch to synthetic oil? (cbmprelude)
I am going to do the same thing. I think you should drain the old oil, otherwise not synthetic and fill with sythetic, new filter and all and run it for a few days, drain, put in fresh then refill.
It would be cool to do that twice, and I think I am. But of course the cost is a factor. I think that would give your engine a chance to circulate out all the old oil. If it wasnt so $$ I would do it 2 or 3 times. Since I just bought my 02 I am going to get the auto tranny done with Royale Purple max syntheic tranny fluid, I hear this stuff is the best. With tranny you can get the flush then fill with the good stuff.
I also think you can get an engine flush, now that can cost you upward to $100 bucks from what I've seen. Just do the 2 change method, it will get rid of most the old non-synth. oil.
Hope this helps, because I am going to do this myself, and if you do this, do it yourself to save some cash.
Peace...
Old Jul 25, 2005 | 09:23 AM
philadd's Avatar
Default Re: switch to synthetic oil? (AccordTunr)
It's not really necessary to flush the motor. Just fill next time with synthetic and call it a day, unless for some reason you feel you just have to have 99% synthetic oil in there right away.
Old Jul 25, 2005 | 09:25 AM
efficiencyJunkie's Avatar
It either hit or miss. It depends on if your car is burning oil right now, and how many miles are on the engine.
my car, a 94 4 banger accord, has 190k. I switched over to full syn at 170k, with very little problems. the first 2 oil changes (done at 6k each) burned about 1/2 quart each. Then that problem just went away. Now I change my oil at 7k.
I would just watch the dipstick, and you will be fine. May even see a *slightly* better mpg!
btw, dont use fram oil filters. Even the supertechs from walmart are better. The purolator pluses are great too!
Modified by carbnjunkie at 10:38 AM 7/25/2005
Old Jul 25, 2005 | 09:35 AM
AccordTunr's Avatar
Default Re: switch to synthetic oil? (carbnjunkie)
I agree with Philadd, doing it myself I may do it twice then take used oil to a recycler. Flushing is to $$$.
I am going to do it my Accord, just got it with 55k on odometer. Does K&N make oil filters? I know they make fuel filters. I want my ride to last, I financed it for 3 years, I want it to be in supremem shape if I sell it.
Peace...
Old Jul 25, 2005 | 09:48 AM
mike_h03's Avatar
i think philadd is rite i drive a 96 accord if i was u i would change it every 3k it's better that way
Old Jul 25, 2005 | 10:46 AM
AccordTunr's Avatar
Default Re: switch to synthetic oil? (sk8erb0i)
True, especially if you want to get every ounce of value out of my car, in 3 years I may not sell it, if I do I can say hey in the 3 years I've owned it it has been taken care of. If I keep it then the car can give me 200k miles without losing a heartbeat.
The latter will probably be true.
Old Jul 25, 2005 | 11:05 AM
James's Avatar
be careful - synthetic oil is thinner than dino oil and with old and worn seals, it can sprang oil leak wherever old seals could not hold in syn oil. My tranny sprung leak after I switched to syn oil and I had to replace all seals. It will not happen every time but in some cases, it did. I think it really depends on the condition of the seals, age and mileage.
Old Jul 25, 2005 | 04:44 PM
ImmaSquashYou's Avatar
Default Re: switch to synthetic oil? (James)
if your care has a lot of mileage. you can mix synthetic oil to introduce your engine to it. that is the safest bet. but ify our car is new with low miles, you can just switch to fully synthetic.
Old Jul 25, 2005 | 05:42 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: switch to synthetic oil? (ImmaSquashYou)
the car has 36xxx miles. So I guess I don't flush it then. Isn't a flush the same thing as if I put in synthetic run the car for say half hour then change it again? do I have to replace the filter as well?
Old Jul 25, 2005 | 06:52 PM
philadd's Avatar
Just do a regular oil and filter change like you normally would, but using the synthetic instead
Old Jul 25, 2005 | 07:39 PM
deserthonda's Avatar
save your money ,the key is to keep it clean replace oil and filter every 3k and you will get 300,000 miles from your engine easily
Old Jul 26, 2005 | 04:09 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: switch to synthetic oil? (deserthonda)
do I have to replace the oil and filter with synthetic every 3000? I thought it was like 7500 if you are using a good brand of synthetic
Old Jul 26, 2005 | 05:10 AM
you dont have to use syntetic oil ...do oil and filter every 3k use any brand of oil you like castrol. valvoline. mobil etc etc
Old Jul 26, 2005 | 06:00 AM
ritepath's Avatar
The easiest way to afford synthetic oil I've found is buy a quart every other trip to wally world. What's that 2 qt's a week? 5-6 bucks a trip won't break you up when food is already 120 bucks/wk.
I just got my 94 with 88k and plan on switching to synthetic sometime over the weekend. I've got around 12qts of full synthetic in the basement now and just changed the jeep's oil this weekend.
Does honda recommend a blend or full synthetic? ifin's honda recommends a blend it's gonna have to wait a few weeks.
Old Jul 26, 2005 | 07:21 AM
phateless's Avatar
don't waste your time/money/oil by changing it twice. no big deal. i put full synthetic in my accord 1t 140k and its at 153k now with no problems. it likes the sysnthetic, seems to rev a little happier at high rpms now. with your new car, just go ahead and switch, you'll be fine.
Old Jul 26, 2005 | 07:38 AM
turboH22Aakkord's Avatar
synthetic oil is awesome... and your car with thank you... but just make sure you use a synthetic filter... i hear that a standard oil filter wont do the job.. i run moble 1 and the moble 1 filter... technically you can run your car 12,500 miles on syntectic oil, but the filter will need to be changed every 5 or 6.. so change the filter, add an extra quart of oil and calll it good..
Old Jul 26, 2005 | 09:29 AM
mike_h03's Avatar
u kno what just change it every 3k cause if u change every 6 or 7 or what ever ur oil is gonna look black if u want to keep it clean i'll change it every 3k
Old Jul 26, 2005 | 09:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8erb0i &raquo;</TD></TR><TR><TD CLASS="quote">u kno what just change it every 3k cause if u change every 6 or 7 or what ever ur oil is gonna look black if u want to keep it clean i'll change it every 3k</TD></TR></TABLE>
definetly... i change mine atleast every 3k... but i was just stating that the moble one car run and is designed to run that many miles...
Spoogen_1
Jun 13, 2007 10:55 AM
Mikey3000
Oct 18, 2003 10:42 PM
andrewasf77
Jan 6, 2003 12:14 PM
self_made
Nov 27, 2002 07:26 PM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
