tach stops working after vtec hits in 99-00 with gsr cluster w h22a motor
Old Jul 25, 2005 | 03:19 AM
AllMotorBrew's Avatar
Default tach stops working after vtec hits in 99-00 with gsr cluster w h22a motor
the h22a motor was a automatic to begin with had the dx cluster so swaped out for the gsr (this is the 4th one to do so i have checked all the wires and all)
when vtec crosses over the tach just falls to 0 then comes back to life once i let off and it falls out of vtec could someone explain what could poss be goin on
thanks logan
Modified by BoostFedBrewer at 6:41 AM 7/25/2005
Old Jul 25, 2005 | 07:20 PM
sockvtec's Avatar
Default Re: tach stops working after vtec hits in 99-00 with gsr cluster w h22a motor (BoostFedBrewer)
boostfedbrewer: bump for me for the late night and also trying to get a gsr cluster to work on a 88-89 crx but all this vss goes here and there and every ****** where and no one really knows where it goes and no sleep is pissin me off im out
Old Jul 25, 2005 | 07:21 PM
JDM-EJ1's Avatar
Maybe a bad connection from the tach to the dizzy? Maybe something is causing a short with the tach wire (I believe it's the blue wire on the dizzy) when VTEC is engauged? That's a shot out in the dark but I would check it.
offspringpunk14
Sep 8, 2009 05:53 PM
GSR936
Dec 29, 2008 01:52 PM
Speed94
Jun 8, 2006 07:19 AM
Chase
33
Sep 29, 2005 07:53 PM
integlude
Jun 28, 2004 03:41 PM
