FUEL CUT OUT AT 3200 rpm (searched)PLEASE HELP
Honestly i read every forum on this subject and i dont think anyone knows what the hell they are talking about... it sounds like the fuel is cutting out at 3200 rpm and bogging out im using a jdm pr3 it started happening even before the car was warmed up and after.... the ECU is not in a hot place and everything is hooked up right it idles a little high but nottin crazy.... plugs are new and wires are good the motor only has 32,000 miles... ive heard ignition problems Map sensor problems fuel pump fuel filter ecu i mean you name it its wrong wtf...... can i get some true straight tech answers here....
Most common to go out (especially on an engine that has been sitting for a year) is the igniter unit in the distributor. You can try scraping the carbon build up off the terminals in it or replace the igniter itself.
If it's acting like it's redlining at 4000 one day and 3000 the next.. it's the igniter. very common. Search "replace igniter "
Thats your answer - thanks for using honda-tech
the engine did sit for a while it actually came from japan and is an 88 motor im getting a code 4 and 6 but a code 4 is a crank sensor and these thing i thoguh only have cam sensors which is part of the dizzy.... remember this was converted from dual point to multi point and i had to do the vtec harness i double checked all the wires and tried alot of different things the site said but nothing i dont think its the ECU....
Either get those ECU codes cleared. (Could be the ECU is in safe mode, possibly)
Or get your ignitor cleaned or get a new one for your distributor.
3200 cut off sounds like the ECU is running in safe mode. I've done the DPFI to MPFI conversion and possibly it could be your wiring is off somehow.
Recheck it again.
-Jon
Recheck it again.
-Jon
