New axels, alignment needed?
B16. I put in 2 new LS axels and now the car shakes a little and pulls to the left. Has anyone else experience this after an axel change? I'm pretty sure it needs an alignment done, but I want to make sure from others experience.
Modified by spoon.eg at 11:35 AM 7/24/2005
how much you pay for em? i need axles 2morrow.. yo get up with me i gotta figure out what **** i need to get this beast n and running it would be easy if i had a motor to look at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">how much you pay for em? i need axles 2morrow.. yo get up with me i gotta figure out what **** i need to get this beast n and running it would be easy if i had a motor to look at.
What the hell did you just say? I don't understand a damn thing you typed. Use some sentence structure and punctuation. That, might clear it up a bit.
Anyways, was everything torqued down to spec?
</TD></TR></TABLE>What the hell did you just say? I don't understand a damn thing you typed. Use some sentence structure and punctuation. That, might clear it up a bit.
Does the car feel like it needs an alignment? If everything was torqued down you should be good. Although, the best way to find out is to just test it.
Get on a straight road and just drive, no hands on the wheel and feel for yourself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Does the car feel like it needs an alignment? If everything was torqued down you should be good. Although, the best way to find out is to just test it.
Get on a straight road and just drive, no hands on the wheel and feel for yourself.</TD></TR></TABLE>
Did that. The car definiley pulls hard, especially when VTEC hits. Car pulls extremely hard.
Yes you need an alignment. Weither you torque everything down to specs or not whenever you take appart your suspension youll more then likely need an alignment, especially when you do an axle. Whenever i do an axle for someone i tell them right away to take it to the alignment and get it done.
dont worry about what i said. I wasnt talkin to you.. your name was no where in my post. the guy that started the thread knows what i mean..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Yes you need an alignment. whenever you take appart your suspension youll more then likely need an alignment, especially when you do an axle.</TD></TR></TABLE>
^^^^listen to this guy. he is speaking facts.^^^^
I know Luserkid is right, I just wanted to make sure before I put out money to get an alignment and its something else.
Thanks for the no sarcasim help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Yes you need an alignment. Weither you torque everything down to specs or not whenever you take appart your suspension youll more then likely need an alignment, especially when you do an axle. Whenever i do an axle for someone i tell them right away to take it to the alignment and get it done. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg »</TD></TR><TR><TD CLASS="quote">I know Luserkid is right, I just wanted to make sure before I put out money to get an alignment and its something else. Thanks for the no sarcasim help.
I know that luserkid usually speaks the truth, but whenever I have replaced my axles (a few occasions), I have never needed an alignment. Like the mod said, make sure that everything is torqued down as it should be as well.
-Shane
</TD></TR></TABLE>I know that luserkid usually speaks the truth, but whenever I have replaced my axles (a few occasions), I have never needed an alignment. Like the mod said, make sure that everything is torqued down as it should be as well.
-Shane
I thought you don't have to since the upper control arm doesn't really get touched...
Anyway, I just replaced my axles and my alignment is still good (steering is straight and doesn't vibrate)
from my experience you need to do alignment everytime you dissassemble anything on the front end accept rotating parts. But you obviously you had to take some of the arms off to get shaft out so will have messed the alignment.
i have just had this same problem as i changed my gearbox and it was solved when i did alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 »</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
Depends on what had been taken off or moved when taking the shafts out. Their a couple off different ways to get shafts out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">dont worry about what i said. I wasnt talkin to you.. your name was no where in my post. the guy that started the thread knows what i mean..
Ease up Cooter. This isn't a chatroom to chat along with people you know. If you post something that has nothing to do with the original question, and want to talk privately with the user, PM him. We don't like private conversations to go back and forth on the thread itself.
If everything is tightened to spec and everything was mounted properly, you might need an alignment. Taking apart the knuckles, and especially the lower ball joint, will throw it out of spec.
</TD></TR></TABLE>Ease up Cooter. This isn't a chatroom to chat along with people you know. If you post something that has nothing to do with the original question, and want to talk privately with the user, PM him. We don't like private conversations to go back and forth on the thread itself.
My shop replaces axles all day, every day, and not one time has a car ever needed an alignment after we're done.
Does the car shake only when you hit the gas? I'll bet it does.
If it does then you got a **** axle my friend, and it's time to get another one. It happens - a lot. We use brand new axles because we'd get 3 shitty rebuilt ones in a row.
Torque steer under throttle, shaking under accleration - = shitty axle.
BTW:
SHAKING HAS NOTHING TO DO WITH AN ALIGNMENT - PERIOD.
I've had countless customers come in a request an alignment, then we do it, and then they say:
"Well my car still shakes on the expressway at 70+mph..."
Well no ****! That's called tire balance issues! People mistake vibrations for alignment all the time, but a car that pulls to the left or right even when the car is in neutral and coasting needs an alignment. People always failt to mention this when they come in, so I try to remember to always ask them why they think they need an alignment, and most of the time it's because of a shaking at certain speeds.
In this specific case I have a strong feeling you got a shitty rebuilt axle. Try and toss the car in neutral while going down the road and I'll bet your vobration and pulling (more the vibration though) goes completely away.
You very well might need an alignment, but I'm willing to bet your bigger issue is the axle.
BTW:
c1v1c98
23
May 16, 2007 09:25 PM
classciv
Jun 7, 2005 05:32 PM
turbod16y7vtec
Sep 29, 2002 10:21 AM
