New b16 turbo not running right.
Old Jul 23, 2005 | 08:33 PM
88crxhfb16's Avatar
Default New b16 turbo not running right.
set up is b16 turbo and is running like ****. idles rough like its about to cut off. give it gas and it sounds like its missing. bogs down and cuts off. lots of smoke. not drivable.
88crx
b16a
garrett t3/t04e
dsm 450cc injectors running off stock CRX HF resistor box.
walboro 255 intank fuel pump
Jackson Racing FMU (center hose to firewall, outer hose to fpr on fuel rail. vacuum source T'd into brake booster at back of manifold)
Turbosmar waste gate (vacumm source t'd into manifold)
also the led's on the injector clips are not on when engine is running???
also testing with a 3in downpipe and no exhaust right now.
any ideas. help.
Old Jul 23, 2005 | 09:49 PM
mbdelsol's Avatar
Default Re: New b16 turbo not running right. (88crxhfb16)
how are you controlling those 450?? chip ecu? vafc?
Old Jul 24, 2005 | 04:28 AM
88crxhfb16's Avatar
Default Re: New b16 turbo not running right. (mbdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mbdelsol &raquo;</TD></TR><TR><TD CLASS="quote">how are you controlling those 450?? chip ecu? vafc?</TD></TR></TABLE>
just running an FMU.
Old Jul 24, 2005 | 04:34 AM
BlueShadow's Avatar
If you're using an FMU you need to use stock injectors. You are running very rich with those 450's and you could flood your motor or wash your rings. You're also supposed to be using an inline pump cause they work best with FMU's.
Old Jul 24, 2005 | 04:39 AM
88crxhfb16's Avatar
Default Re: New b16 turbo not running right. (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">If you're using an FMU you need to use stock injectors. You are running very rich with those 450's and you could flood your motor or wash your rings. You're also supposed to be using an inline pump cause they work best with FMU's.</TD></TR></TABLE>can I ditch the FMU and just run with high Volume fuel pump and the 450 injectors????
Old Jul 24, 2005 | 04:45 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxhfb16 &raquo;</TD></TR><TR><TD CLASS="quote">can I ditch the FMU and just run with high Volume fuel pump and the 450 injectors????</TD></TR></TABLE>
Yes you can as long as you find some way to control the injectors. I saw you looking at the Hondata thread. You can either get the Hondata stage whatever. Or if you have an OBD 0 ECU you can use turboedit. If you have an OBD 1 ECU you can use Crome or Uberdata, or pay a little more money for the Hondata S200 system.
Old Jul 24, 2005 | 04:53 AM
88crxhfb16's Avatar
Yes you can as long as you find some way to control the injectors. I saw you looking at the Hondata thread. You can either get the Hondata stage whatever. Or if you have an OBD 0 ECU you can use turboedit. If you have an OBD 1 ECU you can use Crome or Uberdata, or pay a little more money for the Hondata S200 system. </TD></TR></TABLE>let me see if I understand this correctly, so the 450's can't be used without some type of controller (hondata, aem, etc.) but stock injectors do not require.
Old Jul 24, 2005 | 04:56 AM
88crxhfb16's Avatar
this is the same exact setup that came off my friends b16 and it ran fine. the only difference is he was running Accell 330cc injectors. what could the problem be??
Old Jul 24, 2005 | 05:21 AM
BlueShadow's Avatar
Default Re: (88crxhfb16)
Your friends setup was probably running a little rich, but not to the point where the car would bog at all RPM's. An FMU only raises fuel pressure while you are in boost. So if you were to be running stock injectors with an FMU then under vacuum and idle it would run fine. The turbo's not making any boost so it's as if your car was NA. But as the boost pressure goes up the FMU raises the fuel pressure and forces more fuel out of the stock injectors.
If you get rid of the FMU then you need to find some way to lower the amount of fuel coming out of your 450's at idle, cruising and while in boost. You need to either keep the FMU and switch to stock injectors and get an inline pump. Or you need to ditch the FMU and switch to Hondata, Crome, Uberdata, Neptune or some other form of EMS.
Old Jul 24, 2005 | 05:23 AM
EgLsTurbo's Avatar
Default Re: (BlueShadow)
450cc injectors is your problem u need hondata gonna cost u some money but it should be fine after i had the same problem until i got hondata
Old Jul 24, 2005 | 05:25 AM
EgLsTurbo's Avatar
Default Re: (EgLsTurbo)
also if yoru running from 1-8lbs of boost your better off runnign stock injectors stock injectors does pretty good if your just boosting 8 lbs
Old Jul 24, 2005 | 06:02 AM
88crxhfb16's Avatar
thanks to all who posted.
Old Jul 24, 2005 | 06:04 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgLsTurbo &raquo;</TD></TR><TR><TD CLASS="quote">also if yoru running from 1-8lbs of boost your better off runnign stock injectors stock injectors does pretty good if your just boosting 8 lbs</TD></TR></TABLE>
If you mean just stock injectors and stock ECU then no. If you mean stock injectors and an FMU then yes. However he has a Walbro intank fuel pump. And those aren't meant to be run at the high pressures you see when running an FMU.
Old Jul 25, 2005 | 03:11 AM
88crxhfb16's Avatar
OK, put stock injectors back in, and it seems to be running fine. still not idleing all that well but that should be improved once the exhaust is back on and there is a little backpressure. righ?
Old Jul 25, 2005 | 03:46 AM
Treblarefils's Avatar
probably need a new set of plugs now after trying to run the car on the 450s.
Old Jul 25, 2005 | 05:17 AM
88crxhfb16's Avatar
Default Re: (Treblarefils)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils &raquo;</TD></TR><TR><TD CLASS="quote">probably need a new set of plugs now after trying to run the car on the 450s.</TD></TR></TABLE>good idea. also what plugs and gap should i be running. i'm supposed to use a colder plug right?
Old Jul 25, 2005 | 05:46 AM
SlowB16si's Avatar
colder plugs, I gapped mine .30 - .32
Old Jul 25, 2005 | 09:51 AM
88crxhfb16's Avatar
Default Re: (SlowB16si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowB16si &raquo;</TD></TR><TR><TD CLASS="quote">colder plugs, I gapped mine .30 - .32</TD></TR></TABLE>
anyone got a NGK part number for colder plugs or the ones I should be running???
Old Jul 27, 2005 | 06:39 PM
jdmturbosol's Avatar
bkr7e's gapped at .030
Old Jul 28, 2005 | 03:38 AM
88crxhfb16's Avatar
Default Re: (jdmturbosol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbosol &raquo;</TD></TR><TR><TD CLASS="quote">bkr7e's gapped at .030
</TD></TR></TABLE>thanks man, greatly appreciated.
now what do u think about the new iridium NGK's yes or stay with the regular ones????
Old Jul 28, 2005 | 07:06 AM
1slowhonduh's Avatar
also... stock number for the bkr7e's are 6097... you can get them at advance auto parts... later mike
hotimportcrx
Jun 21, 2005 06:49 PM
hybridpatient95
Mar 13, 2005 05:25 PM
B18PoweredCivic
Jul 25, 2004 12:21 PM
mattb16a1civic
Oct 20, 2003 05:35 PM
ZoNe_HKS
Sep 1, 2003 04:31 PM
