DX to B16 wiring??
Old Jul 23, 2005 | 08:05 PM
RaysBoomBoomLude's Avatar
Default DX to B16 wiring??
ok, anyone have directions on how to wire a DX to B16???
Im putting in a b16 in a few days.
ok, I need to convert to MPFI, I read alot of info for that, but it says i need an SI Dizzy. I kinow a D-SI Dizzy doesnt work for the b16.
so anyone have any other info???
Old Jul 23, 2005 | 08:28 PM
Magick211's Avatar
Default Re: DX to B16 wiring?? (PogiTSI)
Just continue searching on here. There is tons of info
Old Jul 23, 2005 | 08:54 PM
CRX Toad's Avatar
Default Re: DX to B16 wiring?? (Magick211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Just continue searching on here. There is tons of info</TD></TR></TABLE>
I will give you a little hint. http://www.fourthgenhatch.com you must complete your journey from there wee grasshopper
Old Jul 23, 2005 | 09:38 PM
Default Re: DX to B16 wiring?? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I will give you a little hint. http://www.fourthgenhatch.com you must complete your journey from there wee grasshopper</TD></TR></TABLE>
I read that websight.
so doing a MPFI on a b16 is the same as a D16a6??? thanks.
Old Jul 23, 2005 | 10:14 PM
Magick211's Avatar
Yeah basically your doing the same thing as d16a6 to b16. but you're also converting to mpfi at the same time
Old Jul 24, 2005 | 01:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah basically your doing the same thing as d16a6 to b16. but you're also converting to mpfi at the same time</TD></TR></TABLE>
ohhhhhhh sounds easy enough. Looks like im off to the junkyard tommaro, Pull some Injector Plugs\ECU pins.
cehcivic15
Jul 18, 2008 06:10 PM
nihad
Apr 19, 2007 08:05 PM
88crxhfb16
Apr 15, 2006 08:42 AM
MikeSarr_GSR
152
Sep 2, 2004 05:19 AM
DubyaAye
Jan 11, 2004 10:57 PM
