Installed Walbro 255hp pump fuel pressure dropped.
Old Jul 23, 2005 | 07:26 PM
Boognish's Avatar
Default Installed Walbro 255hp pump fuel pressure dropped.
So I installed the pump and when I start the car the fuel press is down from 40 to 20 and it stays there so the car wont run.
Anyone had this happen?
I have a FPR should I just try to crank up the pressure or is something else wrong here?
Help.
Old Jul 24, 2005 | 11:39 AM
mtber's Avatar
Default Re: Installed Walbro 255hp pump fuel pressure dropped. (Boognish)
Normally the fuel pressure will rise over what it was on the stock fuel pump....
What fuel regulator are you using ?
Something doesnt sound right.
Old Jul 24, 2005 | 11:50 AM
inspyral's Avatar
That definitely doesn't sound right. When I put my Walbro 255hp in, my fuel pressure went up about 5-10 psi at the rail, and I had to lower it a bit. This is with a stock rail, and an AEM fpr.
Old Jul 24, 2005 | 08:16 PM
Boognish's Avatar
Default Re: (inspyral)
It was just low on fuel and I guess since there was no pressure in the system after the install, the pressure was low.
The gas gauge was still showing it had some but I guess it wasnt enough.
Easiest fix ever lol.
jman86
Nov 7, 2024 12:19 PM
si90rex
15
May 18, 2010 05:03 PM
scuffywin
Jun 5, 2007 04:15 PM
Daniel-sanB1
May 28, 2006 10:31 PM
BoOsTiN Dc2
Feb 1, 2005 10:05 AM
