Crank Fluctuation Sensor + B16A
Ok, here's the scoop. I'm trying to put a B16A in the cone because I'm broke. I have an OBD 0 one. I just realized that it'll need what is commonly referred to as a crank position sensor (but is actually a crank fluctuation sensor) installed. I know it goes on the exterior of the oil pump below the crank. I know it requires an additional bracket. Does it require any thing else (drilled holes, bolts, etc) or does it just mount right up? Any advice on this would be greatly appreciated. Thanks!
as far as i know, the only proper way to mount it is get a 96+ oil pump for any bseries and the sensor bolts up to it.
Zedt3
11
Jul 18, 2008 07:51 PM
twinj
10
Apr 19, 2007 07:18 AM
1998, 92, b16, b16a, buy, crank, crankshaft, fluctuation, flucuation, honda, location, pictures, sensor
