can you tell me what turbo is this ?
Old Jul 23, 2005 | 06:16 PM
EK FLY's Avatar
Default can you tell me what turbo is this ?
anyone or if anyone have this turbo runing on ur engine let know how it is
Old Jul 23, 2005 | 06:29 PM
PrettyLude's Avatar
t3 60 trim?
Old Jul 23, 2005 | 06:37 PM
turboEGhatch's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">t3 60 trim? </TD></TR></TABLE>
That's definitely a TO4E compressor housing.
Now you just gotta pull off the housings and measure the inducer and exducer on both, and check for any number markings and bring them back to us.
The turbine side should say .48 A/R, .63 A/R, or .82 A/R. The compressor side should say .50 A/R, but there should be a name plate with serial and model numbers on the back plates.
Old Jul 23, 2005 | 07:05 PM
PrettyLude's Avatar
i've never seen an to4e with an internal gate
Old Jul 23, 2005 | 07:13 PM
EK FLY's Avatar
bump for more info plz
Old Jul 23, 2005 | 07:16 PM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i've never seen an to4e with an internal gate</TD></TR></TABLE>
That's because it is a T3/T4 "hybrid".
Using the T3 internal gate seems like a bad match for the T4 compressor. The car that this is intended for will produce way too much exhaust for that little wastegate flapper to handle.
But you could just unbolt the internal wastegate and replace it with a standard 5-bolt T3 flange.
BTW the thing isn't professionally done. Someone just bought some parts on Ebay and decided the make it themselves. I wouldn't be surprised if it wasn't rebalanced after swapping the compressor wheels.
Old Jul 23, 2005 | 07:50 PM
EK FLY's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">That's because it is a T3/T4 "hybrid".
BTW the thing isn't professionally done. Someone just bought some parts on Ebay and decided the make it themselves. I wouldn't be surprised if it wasn't rebalanced after swapping the compressor wheels.</TD></TR></TABLE>
yea there is this part of the turbo by the turbine side that cover the wastegate wich it can be unbolted but you will still see the wastegate ... how can I tap that internal wastegate.. and make it external ?
Old Jul 23, 2005 | 10:20 PM
One of those DSM turbo companies makes a hybrid with a T66 comp wheel in a TO4E housing with an internal gate, so I don't think a T3/TO4E 57-trim or whatever this is is too much of a strech.
You can't rule this out as a hybrid that somebody made in their back yard untill we know what kind of exhaust wheel is in it.
EKlscoupe_98
Northeast (Sales)
Oct 7, 2008 07:10 PM
Humble Performance
Nov 28, 2006 06:12 PM
dnbruut
Jul 8, 2005 07:57 AM
h22turbolude
Dec 10, 2003 08:39 AM
Crazy Cooter
Oct 10, 2003 04:28 PM
