obx manifold problem
Old Jul 23, 2005 | 06:10 PM
hbracer's Avatar
Default obx manifold problem
hey i just got back from a friends house were my buddy was installin an obx manifold on the moderatley built d16, everything went together alright a few adjustments here and there and when we went to start it up it started and immediatley revved to redline so we switched around a few vacum lines and it still did the same thing after doing this 10-15 times we decided that its either a vacum problem or the gasket is leaking and the air is comin in around the manifold-head gap. also when is revs after the start it has a loud whistle could that be the air gettin sucked in through the wrong place? and if it is around the mani-head gap how would we stop it?
Old Jul 23, 2005 | 06:28 PM
chris_m's Avatar
* B A N N E D *
Default Re: obx manifold problem (hbracer)
obx what a surprise but did you use a new gasket
Old Jul 23, 2005 | 06:40 PM
GOLDBERG's Avatar
Default Re: obx manifold problem (Christopher M)
its probably a installation problem...is your throttlebody open...............?
Old Jul 23, 2005 | 06:42 PM
philafelman's Avatar
Default Re: obx manifold problem (GOLDBERG)
sounds like the throttle is stuck open.
Old Jul 23, 2005 | 06:59 PM
hbracer's Avatar
no its not a mod from SHO said its most likely an intake gasket leake because the one we used was ****, and it was makin a loud whistle sound
Old Jul 23, 2005 | 07:05 PM
Yambor's Avatar
Default Re: (hbracer)
def a vacuum problem..get a oem honda gasket and retry it..
gil_Type R
Apr 21, 2010 08:42 AM
AllmotorGSReg
Nov 19, 2009 12:12 PM
turbotime
Dec 13, 2005 01:08 PM
esoterEK..
Mar 25, 2004 06:14 PM
PM-Performance
Jan 23, 2003 08:12 AM
