Anyone use STR fuel rail with JG manifold....pic inside.....
Old Jul 23, 2005 | 05:13 PM
mrbsponge's Avatar
Default Anyone use STR fuel rail with JG manifold....pic inside.....
currently i am running the AEBS manifold and i DO NOT like it, i think it is a POS. so i have ordered a JG edelbrock, but i have seen some things about the Regulator not fitting on the rail, but most i have seen are stock or the AEM, i am using an AEM regulator, but mine seems to be on the end of the old school STR fuel rail.
does anyone know if this will fit without an adapter??
Old Jul 23, 2005 | 05:23 PM
Danger's Avatar
Default Re: Anyone use STR fuel rail with JG manifold....pic inside..... (mrbsponge)
i doubt it will fit . buddy of mine had the AEM rail and fpr... he had to get the adapter piece from the JRSC kits .
Old Jul 23, 2005 | 05:38 PM
mrbsponge's Avatar
i think camp1320 sells them for like 20 bux, cause i damn sure dont wanna pay 50.
i remember with my JR blower, i swapped to a different fuel rail and my regulator was fine.
i think the AEM regulator(spot on the rail) is slightly moved to the left tho
Old Jul 23, 2005 | 05:52 PM
m R g S r's Avatar
Default Re: (mrbsponge)
I dont think it will fit.
I have the venom IM and aem rail with stock fpr andthe nipple on the fpr hits the plenum on my intake manifold.
Old Jul 23, 2005 | 09:17 PM
SuperTeg95's Avatar
Default Re: (m R g S r)
I cant remember for sure, but I think if you mount the regulator upside down it will work.
Old Jul 23, 2005 | 09:35 PM
D-tuned's Avatar
Default Re: (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">I cant remember for sure, but I think if you mount the regulator upside down it will work. </TD></TR></TABLE>
Old Jul 23, 2005 | 09:45 PM
epic1si's Avatar
you have to use the adapter that angles the fpr off to the side a little bit. i'm currently using the jd edelbrock IM with AEM fpr and it fits.
Old Jul 23, 2005 | 11:46 PM
BoostedJeff's Avatar
Default Re: (epic1si)
i have the same fuel rail as that, and the same FPR as that, and i have no problem, you just have to wigge the fuel line little by little on there. Once it is on, its perfect
Old Jul 24, 2005 | 05:32 AM
alpha's Avatar
Come on Mike. Show some real pictures of this 650whp beast
Old Jul 24, 2005 | 09:46 AM
mrbsponge's Avatar
thanks guys, i would hate for the new manifold to get here and have to order something else afterwards.
and i wish i was 650!
Old Jul 24, 2005 | 10:09 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys, i would hate for the new manifold to get here and have to order something else afterwards.
and i wish i was 650!</TD></TR></TABLE>
Yeah Yeah Yeah
Old Jul 24, 2005 | 10:18 AM
rudebwoy's Avatar
I use a jg manifold with aem fpr and regulator and I had to get the adapter from camp1320 to make it fit the outlet on the bottom of the fpr touches the manifold. so two to fix that is adapter, or use a 90 degree fitting on the fpr.
Old Jul 24, 2005 | 10:26 AM
rmcdaniels's Avatar
I just tapped my fuel rail and my AEM FPR with a 1/8" NPT tap, then put hose barbs on each piece and put a 4" piece of fuel line between them. Works great, and cheap too!
Old Jul 24, 2005 | 12:35 PM
mrbsponge's Avatar
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">I just tapped my fuel rail and my AEM FPR with a 1/8" NPT tap, then put hose barbs on each piece and put a 4" piece of fuel line between them. Works great, and cheap too!</TD></TR></TABLE>
i was thinking about this as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I use a jg manifold with aem fpr and regulator and I had to get the adapter from camp1320 to make it fit the outlet on the bottom of the fpr touches the manifold. so two to fix that is adapter, or use a 90 degree fitting on the fpr. </TD></TR></TABLE>
i think the AEM FUEL RAIL places the regulator in a stock location, which is slightly more left than the STR which is all the way at the end, i wish i had a good pic of the AEM rail
Old Jul 24, 2005 | 01:26 PM
M.A.R.C.'s Avatar
i have a jg manifold with an oem regulator. i had to flip it upside down to fit. before i went back to the oem regulator i had an aeromotive bolt on regulator... that couldn't fit normalyl or upside down. with an aem regulator or any other bolt on regulator i'd think you need to use the JRSC piece or some other adapter.
Old Jul 28, 2005 | 01:40 AM
jdmsiR20's Avatar
Default Re: (M.A.R.C.)
hey there... just wondering why u dont like ur AEBS?
Old Jul 28, 2005 | 06:47 PM
FullRaceTurboSi's Avatar
It will work on the b16 Edelbrock intake manifold if you flip the fpr upside down but on the b18c Edelbrock intake manifold you would have to get a adapter plate or go to with a fpr that doesnt go on the fuel rail
Old Jul 28, 2005 | 07:02 PM
lucidvtec's Avatar
ya why don't you like the aebs mani...i have a b18c1 i thought it would make a diff on my setup ...i got a new 65mm tb as well ...isn't alot better than the gsr intake mani
97gsrki
Aug 20, 2007 07:44 PM
EGB18C
Mar 19, 2007 10:38 PM
GruvyTune
Feb 13, 2005 04:57 PM
AL ASPIRATED
Sep 1, 2004 09:46 AM
1badda
Feb 12, 2004 10:00 PM
