length of engine swap?
this is going to be my first engine swap, i'm putting a B18C1 into my 2000 civic ex coupe. im getting the motor, tranny, and ECU all from the same guy. i have a mechanical know-how and a repair manual to guide me, so im wondering about how long did it take you guys on average to swap a motor the first time you did it? also do you know if all of the motor mounts will line up, or will that take some custom fabrication? thanks guys
It will take between 5hrs - the whole weekend. It just depends on how you allocate your time, how many times you need to run to Home Depot to pick up bolts, if you're missing parts, if everything lines up, etc...
here man..ill save you some flamming issues...
https://honda-tech.com/zerothread?id=642479
most of the stuff you can find here..or search!
big-cat
Mar 19, 2006 06:59 PM
