I screwed up big time: NEED HELP!!!
Old Jul 23, 2005 | 02:46 PM
Scartissue's Avatar
Default I screwed up big time: NEED HELP!!!
I was in the process of removing the sound deadening in my car so that I could install brand new b-quite throughout.
Well, after I applied the dry ice and was beginning to remove the sound deadening on the passenger side, I punched a hole through the sheet metal. I found myself staring at the pavement through a half-dime sized hole. I was using a chisel to start a section to where I could begin using a putting knife and I used a bit too much force.
So my question is, what the hell do I do now. How do i get this fixed?? How much will it cost to get fixed?
I know it was stupid, but it was a mistake...damn this sucks. any help/advice would be appreciated.
Old Jul 23, 2005 | 02:54 PM
Liquid Ice NF's Avatar
Quickand easy way.. Bondo
get a little kit.. it will come with directions.. and if u wanted to.. u can touch it up with a little paint.
or u can replace the whole sheet-metal... but that will cost a lot more
Old Jul 23, 2005 | 03:01 PM
Scartissue's Avatar
Default Re: (Liquid Ice NF)
and can I buy a bondo kit at any auto parts store like kragen?
Will I have to worry about rust? Should I get some rustoleum and spray it down before I bondo?
Thanks for the help. It is greatly appreciated.
Old Jul 23, 2005 | 03:25 PM
EMJAY's Avatar
man you can get bondo at wal-mart...
Old Jul 23, 2005 | 03:26 PM
ya man. tell the guy at the store exactly what you did, and he can prob help u out. you may even be able to find a kit at a hardware store.
it prob wont rust.. but when ur done with the bondo process and its dry.. spray a little primer on there to prevent rust. but rustoleum would work too
Old Jul 23, 2005 | 03:28 PM
Default Re: (kb12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb12 &raquo;</TD></TR><TR><TD CLASS="quote">man you can get bondo at wal-mart...</TD></TR></TABLE>
you can get anything at walmart. lol
i'm suprised they dont do swaps yet.
Old Jul 23, 2005 | 04:21 PM
Scartissue's Avatar
Thanks a lot for the help Liquid, I really appreciate it!
Old Jul 24, 2005 | 02:03 PM
integracecraft's Avatar
Default Re: (Scartissue)
go to car-parts.com its an insurance junkyard part seach. you can get a door for like 200 bucks!
Old Jul 24, 2005 | 03:33 PM
jennifermike's Avatar
Default Re: (integracecraft)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracecraft &raquo;</TD></TR><TR><TD CLASS="quote">go to car-parts.com its an insurance junkyard part seach. you can get a door for like 200 bucks!</TD></TR></TABLE>he didnt put a hole in his ******* door, its his floor
Old Jul 24, 2005 | 04:43 PM
Racermech's Avatar
Default Re: (jennifermike)
Bondo can crack and eventually break away. Best way will be to get the hole welded up.. If you are in so cal I could do it for you. If it is just a dime size hole you would not even have to use any back up material, you could just keep spot welding the hole till it is filled. A welding shop will do it for you cheap, then you just need to grind it down a liitle and you are set
dlx111
Paint and Body
Sep 15, 2013 02:06 PM
NACvicSi
Paint and Body
Jul 1, 2009 08:33 PM
brokenef8
Paint and Body
Oct 12, 2007 07:49 PM
vtecn8ive
Mar 3, 2005 10:23 AM
86_CRX_FOR_LIFE
Oct 22, 2002 05:09 PM
