Help Redoing this piece
Old Sep 12, 2013 | 07:34 AM
dlx111's Avatar
Default Help Redoing this piece
not sure what trim this is called but its the piece on either side of the roof on an ej2. I used an exacto knife to cut away then sand down the window trims like this but these pieces are giving me more trouble. is there any other method besides cutting or scraping the old black off?
Old Sep 12, 2013 | 07:46 AM
wicked_jeb's Avatar
Default Re: Help Redoing this piece
http://www.hondaautomotiveparts.com/...NG+-+PROTECTOR
#'s 7 & 9
Old Sep 12, 2013 | 10:12 AM
dlx111's Avatar
Thnx
Old Sep 12, 2013 | 10:42 AM
Fibercation's Avatar
paint thinner? sanding it?
Old Sep 12, 2013 | 04:14 PM
hapwarehouse's Avatar
40 grit sand paper, then 80 grit, then 320 grit and finish it with 800, scotch it before you paint
Old Sep 12, 2013 | 04:52 PM
PanchoEK's Avatar
I would say not even worth the time and hassle of repairing, just buy new ones
Old Sep 13, 2013 | 11:37 PM
kid6061's Avatar
In my opinion the fastest least labor intensive way would be to take a drill electric or pneumatic with a 2-3 inch soft / medium wire wheel (under $5.00 at Harbor Freight) and remove the original finish. It should remove it quickly and cleanly but, be careful not to warp the piece as doing so generates a lot of heat. After that go over it with a lighter sand paper 600-800, clean it real well, spray a DTM primer and then black trim paint and then you have a like new roof trim. It's not too hard but up to you if you want to put in the effort. Hope this helped and good luck.
Old Sep 15, 2013 | 02:06 PM
whitechihatch's Avatar
sand it down to bare metal and spray it with plati dip i did this on my 96 hatch and they came out brand new
lostforawhile
Oct 5, 2014 03:29 PM
fhukingviet
Jul 27, 2009 11:44 AM
prjct92eh2
Paint and Body
Nov 3, 2008 07:13 AM
pxsx
Oct 11, 2008 06:45 AM
g0tgot
Paint and Body
Dec 16, 2007 11:41 AM
