How To: Quaife Steering into EG
Old Jul 23, 2005 | 11:54 AM
litterbox's Avatar
I am a (Trial User) Army
Default How To: Quaife Steering into EG
REVIEW ON PAGE 2!
Hey Guys,
Am I the only one that hates that loose play in the steering wheel and the feeling that you need to turn the steering wheel about 180 degrees just to turn the car a little bit? This is the solution for you: Quaife steering rack and pinion, it reduces the LTL from 4.0 to 3.25. This should help on the road or autocross course as well.
The following is my experience with the install:
Ok, first off, I definitely recommend that you do this when your bay is empty, like so:
The first thing you will need to do is jack up the front of the car, remove the wheels and pop out the tie rod ends, like so (tie rod ends removed)
Now you need to remove the steering rack. It has 4 bolts that attach it to the subframe, 2 on left, and 2 on right (in this pic, the steering rack has already been removed, but you can see the holes):
Left side:
Right (driver) side:
Now, go inside the car and pull the carpet back to expose where the steering column meets the rack:
There is a 10mm bolt that needs to be removed (already done in pic):
You can see the threaded hole in this pic (bad pic):
Now you can remove the entire rack from the car and it'll look like this. (I don't know where my shoes went in this pic) :
Slide the cover off:
Unscrew that bolt:
Once bolt is undone, you'll find a spring revealed and some other parts:
Ok, from this angle, there is a seal (not shown) that you need to gently pry out. Careful, it might tear and you'll have to get a new one. I tore mine.
After you remove that seal, you'll see this circular clip that needs to be removed:
Ok, so now you're actually at this step:
Now what you do is hold the pinion rod with your hand and hammer the rack to pull out the pinion and bearing:
Once it's out, it'll look like this (the bearing is pressed on it, and there is a clip in the middle right above the bearing that fits into a groove on the actual pinion, I'll need to order a new clip because i can't get that one off:
So the pinion is removed, now it's time to remove the rack. First start by undoing those clips that hold the boots on each side in place. You'll need to pry them up with a flathead or something. Don't ruin them, they will be reused:
Once the clip is removed, slide the boot off and the rack will follow:
You'll then need unbolt the rack from the inner side of the tie rods. You'll need a damn big wrench. It'll look like this when done:
The other side is the same:
Now take the new rack and slide it in the rack casing and bolt each tie rod end back to it.
It's now time to put the pinion in place. First press the new bearing on the pinion just like the stock one. Press the bearing all the way down to where the groove in the pinion is revealed. Remember that's for the clip to go to hold the bearing in place. That clip is in place in this pic:
Here's the box the bearing came in
Now slide the pinion with bearing back in place, it might need a little tapping, place the circular clip in, then put the seal on top of that, then put the cover thing back on it and you're all done! Just bolt the rack back in place.
Here's a pic of the old rack and pinion, they make good weapons:
I haven't actually tested this setup yet because I don't have the engine in yet, but I'll definitely report back once the car is drivable.
Hope this helps everyone.
Modified by litterbox at 8:09 AM 8/29/2005
Old Jul 23, 2005 | 12:11 PM
Archidictus's Avatar
Unceasing Measure
Badass write-up, Litterbox. Keep this **** coming !
Old Jul 23, 2005 | 12:15 PM
fasthatchb18c1's Avatar
Default Re: How To: Quaife Steering into EG (litterbox)
Nice
Old Jul 23, 2005 | 12:27 PM
StreetEG's Avatar
Default Re: How To: Quaife Steering into EG (fasthatchb18c1)
Very nice write-up...how much was teh kit? and how long did it take?
Old Jul 23, 2005 | 12:28 PM
turboman's Avatar
That is nice I really want this for my car.
Old Jul 23, 2005 | 12:29 PM
momstaxi's Avatar
superb write up man
just wondering where you purchased the rank and pinion from and price?
very cool man
Old Jul 23, 2005 | 12:33 PM
EK k kay's Avatar
Default Re: How To: Quaife Steering into EG (momstaxi)
Awesome detailed write up with lots of pics
Old Jul 23, 2005 | 12:45 PM
litterbox's Avatar
Default Re: How To: Quaife Steering into EG (my head a plode)
Thanks for the positive reviews guys! I bought the kit directly from Quaife because their dealers didn't stock them or didn't offer any sort of lowered price.
http://www.quaifeamerica.com <--then click suspension. I payed $240.
Old Jul 23, 2005 | 12:48 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
aren't you supposed to press the bearing onto the pinion shaft?
Old Jul 23, 2005 | 12:51 PM
litterbox's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^^whatnoobsearchthenGTFO &raquo;</TD></TR><TR><TD CLASS="quote">aren't you supposed to press the bearing onto the pinion shaft?</TD></TR></TABLE>Yes you are. I viced the pinion and tapped it and got it down to where it's supposed to sit.
Old Jul 23, 2005 | 12:52 PM
GetawayInMoscow's Avatar
Great write up
You work on your car barefoot?
Old Jul 23, 2005 | 01:39 PM
JDMSiGuy17's Avatar
great write up and very pic intensive!
Old Jul 23, 2005 | 03:22 PM
cxSHOE's Avatar
looking good.
Old Jul 23, 2005 | 03:40 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (litterbox)
Nice write up Jorge
I wish I had a clue on what to do
Old Jul 23, 2005 | 03:45 PM
Luserkid's Avatar
Default Re: How To: Quaife Steering into EG (cxSHOE)
Not bad not bad. It would be nice to see the process of putting things back. I know its all backwards but its still cool
Did you really work in the rain? That sucks, i did a swap in the rain once got sick as hell. Never again. And you had no shoes
Good job man
Old Jul 23, 2005 | 03:48 PM
Deemeetree's Avatar
Electrician
Hah, *** bearings. I remember those, my friend used them a lot on his VW.
Great write-up man! Definitely in the FAQ page.
Old Jul 23, 2005 | 03:52 PM
Kyles ej1's Avatar
Default Re: (Deemeetree)
how much harder would it be to do it with the engine in? cuz i hate my steering and how much did that cost?
Old Jul 23, 2005 | 04:02 PM
MatHadder's Avatar
Default Re: (93ejay1)
Nice write up. Cant wait to hear how it all works.
Old Jul 23, 2005 | 04:32 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: (MatHadder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Badass write-up, Litterbox. Keep this **** coming !</TD></TR></TABLE>
Definitely second this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">Great write up
You work on your car barefoot? </TD></TR></TABLE>
I was wondering the same thing. Do you not like your toes or something? lol
Old Jul 23, 2005 | 04:33 PM
Ricey McRicerton's Avatar
Default Re: (Archidictus)
Hell yes. I can't wait to hear how this works. I hate my steering as is.
Old Jul 23, 2005 | 05:03 PM
pdiggitydogg's Avatar
pff...***...
very nice - I might look into this rack too....oh wait, theres no ek!
Old Jul 23, 2005 | 05:48 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (pdiggitydogg)
That write up is bad as hell. I was originally going to buy this as soon as it came out, but they changed the advertised steering response. It originally said it was going down to 2.8 turns lock to lock for the EG, but then they switched to 3.x. Needless to say I was dissapointed. I don't know why, but my stock EG (94cx) has only 3.6 turns L2L, while my stock 89 CRX Si has slightly over 4. WTF! Why do people say theirs is the opposite?
Old Jul 23, 2005 | 05:52 PM
dh's Avatar
dh
Default Re: (94eg!)
Nice write up
Old Jul 23, 2005 | 06:39 PM
seoul-child's Avatar
nice write up
Old Jul 23, 2005 | 06:40 PM
JDM-EJ1's Avatar
Nice man. Very nice.
