relayed alarm to turbo timer, but shock sensor is too sensitive.HOW can i relay the shock sensor to
Old Jul 23, 2005 | 11:48 AM
iRIDEdumped's Avatar
Default relayed alarm to turbo timer, but shock sensor is too sensitive.HOW can i relay the shock sensor to
i put a relay so i can arm me car while the turbo timer is on, but my shock sensor is just too sensitive or my car just vibrates too much. i was wondering if there was a way to put a relay or something so that my shock sensor is off while the car is running, but when the turbo timer turns off it will arm the shock sensor again?
thanks in advance
Old Jul 23, 2005 | 11:53 AM
lucidvtec's Avatar
i don't know how good of and installer you are..but you need to get a adj. pulse timer...dei makes one part number 510t should be less than 20bux....use the status output on the autostart with the pulse timer to bypass the shock sensor signal input wire....BAM
Old Jul 23, 2005 | 12:43 PM
i dont think my alarm has auto start. its just a regular prestige alarm that was already hooked up to the car when i bought it, but i pretty much can figure out where most of the wires are. my tubo timer is an old school apex timer. is there a wire on the shock sensor i can wire to a relay to make it turn off when the timer is on?
Old Jul 23, 2005 | 03:17 PM
lucidvtec's Avatar
ya you will have to use a relay off your negative armed output to the pulse timer that breaks the signal wire on your shock sensor..it will only disable the shock once the alarm is activated for the set time on the pulse timer...end
Old Jul 24, 2005 | 05:20 PM
is there anyway you could please explain this is detail, cuz i suck at wiring
Old Jul 24, 2005 | 08:44 PM
lucidvtec's Avatar
i would up on relays' and how they work..just look up the 5pole relays...u can use them for all sorts of thing's...great for isolatin...MAKE SURE YOU FUSE ALL 12V CONNECTIONS...within 8inchs from the connection...i suggest close as possible...get urself a good pair of crimpers...like klien..snapon....greenlee.....have fun and good luck
weekendboost
Audio / Security / Video
Dec 11, 2017 02:59 AM
Nameless RB26
Sep 16, 2003 11:36 AM
Greyout
Jul 24, 2003 06:15 AM
nd8ch
May 19, 2003 04:15 PM
Undepelo
22
Sep 26, 2002 05:51 PM
