Need help where is the relay located on 95 ex accord
Old Jul 23, 2005 | 08:57 AM
jdmep3's Avatar
Default Need help where is the relay located on 95 ex accord
My brother's headlight doesn't work ! Anyone here knows where is the headlight relay? Thanks in advance!
Old Jul 24, 2005 | 06:13 PM
jdmep3's Avatar
Default Re: Need help where is the relay located on 95 ex accord (jdmep3)
Bump
Old Jul 25, 2005 | 06:27 AM
deserthonda's Avatar
underhood fuse box
Old Jul 25, 2005 | 09:00 AM
jdmep3's Avatar
I changed that relay already but the headlight still not work !
Old Jul 25, 2005 | 08:15 PM
Default Re: (jdmep3)
than you got another problem ,,,,,fuse ok? could be a bad headlite switch
Old Jul 29, 2005 | 08:28 AM
jdmep3's Avatar
I changed the headlight switch too
Old Jul 29, 2005 | 09:54 AM
well jd if fuse , relay and headlite switch are all ok you might have a wiring problem , bad connection?? .... get a voltmeter ,,,, start tracing wires
Old Jul 29, 2005 | 10:06 AM
Default Re: (deserthonda)
underhood fuse box did you chk all 3 fuses?? # 19, # 20 and # 32??? a silly question the bulbs are ok right ?? you dont get either low or high beams right??
so i am assuming you chk for power and ground at headlamps plug and you are not getting power?? or ground??,, there is also a big main fuse 100 amps fuse # 15 it is ok ??......... also above left kick panel there is a 20 pins gray/blue connector chk for power there at wires red/green and blue/red... you might have to turn headlite switch on ,,, that ought to give u some to do
post the results ,,
Old Jul 31, 2005 | 04:30 AM
jdmep3's Avatar
thanks for your reply I gonna to check all these wires and fuses tomorrow! I let you know
thekingofvtec
Jun 12, 2018 02:29 PM
sam27
Honda CR-V & Element
Mar 10, 2016 04:24 PM
ser13
Dec 26, 2007 12:58 PM
tanyeung
Apr 7, 2006 04:53 AM
ef civic
24
Dec 9, 2002 10:01 PM
