ECU Trouble Codes 89 4-DR DX
im throwin trouble codes 1 (o2 sensor) & 15 (injection output signal)! what else could be wrong to throw those 2 codes? ive changed plugs, cap, button, coil, wires, checked timing. the car has no power and a real bad miss though the rpms. and is drinkin alot of gas!!!!!!!!!
o2 sensor code means your o2 sensor is bad. Therefore, replace it. o2 sensor determines how much fuel you're going to get as well, so that would make sense in regards to why you are guzzling gas. Injection output signal I would assume means either an issue w/ an injector or a problem in one of the wires. They're both pretty self explanatory.
I'm telling you dude. Replace the O2 sensor, and check the MAIN INJECTOR. I believe that is the one w/ the green plug. It is probably failing. THAT IS THE ONLY THING THAT CAN THROW THOSE CODES. O2 SENSOR = O2 SENOR AND INJECTOR = INJECTOR.
anothersickhatch
May 15, 2004 10:22 PM
