whos running a custom/sheet metal intake manifold? questions.
Old Feb 18, 2002 | 01:02 PM
Markaccord95's Avatar
Default whos running a custom/sheet metal intake manifold? questions.
for example, I have the Venom manifold. More then likely, the air intake temp sensor will just be mounted in a runner, and the EGR blocked off. Question being, what does everyone do about the Idle air control valve? Where did you mount it? Also, how messed up will the car idle without it, or is their any alternative ideas? Thanks
Old Feb 18, 2002 | 07:11 PM
Default Re: whos running a custom/sheet metal intake manifold? questions. (Markaccord95)
up
Old Feb 19, 2002 | 05:48 AM
rtype11's Avatar
no IAC, just play with Idle screw, not sure if you can manage this without standalone. the ECU would pobably look for the IAC input???
illprelude
Jul 11, 2008 05:04 AM
tuningrookie
Jan 20, 2008 12:53 PM
EVILD16BSTD
Mar 30, 2003 01:38 PM
Markaccord95
Feb 19, 2002 10:04 PM
